onChange evnets in Layer panel and layer content (Text content change, width, height etc)
  • September 1, 2021
  • 1033 views
Hi Figma,
I was looking to create a Plugin to call a function on layer rename. So far I was only able to do it with the help of on("selectionchange") and custom JS code to check if we changed the layer name.
I was wondering if Figma Plugin API has some deeper integration of event triggers like layerRename or layer order change etc. OR if somehow we can add event handlers to figma UI’s DOM change, and monitor layerOrder or layerName changes.
Second part of the problem is to detect the figma Artboard canvas changes, like is there a Plugin API to detect that I changed the text content of TextNode, or if I changed the width/height of RectangleNode etc.
Best answer by Gleb
There are no events for anything of this sort. You can run a check for the properties you need using setInterval every second or so. This is enough for most tasks and works fine.
  • 4709 replies
  • September 1, 2021
That was also my approach to go about it. Seems like a little performance overhead in the Plugin Design
