sebastien.giroux
Active Member
Mar 19, 2021 1:03 PM UTC
Multiple independent strokes
You can currently set multiple stroke colours to an object, but they will share the same properties (thickness, position, etc.).
My idea is that you should be able to set all stroke properties on each stroke:
Make sense or am I missing something?
Alex_K
Oct 9, 2021 7:34 AM UTC
+1, I’d love this!
Sean.Mihaly
Nov 8, 2021 7:05 PM UTC
This 1000%.
It’s not uncommon for UI elements with multiple states to have multiple strokes. You can often use dropshadow effects with Spread to mimic this, but this doesn’t work on vectors. This is also a very common thing that is easily done using CSS. Bringing Figma closer to parity with what CSS can do will only benefit designers.
MMM
Dec 15, 2021 8:54 AM UTC
please add double stroke to object. now i can add different colours, but size change stroke to all colours. i can’t create stroke to object with free space between line and object. and can’t create two stroke lines with different colours
Frazer
Dec 21, 2021 11:24 PM UTC
+1 please. The separation in colour makes independent stroke width needed.
Keep it up crew, appreciate all the hard work!
Agne_Petrauskaite
Jan 7, 2022 5:34 PM UTC
Yes, please. Much needed 😊
Isaiah
Jan 13, 2022 2:06 PM UTC
Agreed, this definitely needs to be added.
Franco_Andrade
Active Member
Jan 19, 2022 12:22 PM UTC
This is a must.
Nicolas_Simon
Jan 20, 2022 12:13 PM UTC
+1 I’d love this
Dylan_Reece
Jan 27, 2022 2:38 AM UTC
Just like Photoshop. You can say it.
donnavitan
Jan 27, 2022 2:13 PM UTC
+1 Need this please.
