Links are not leading to the screen, only the file
Wolf_Or
When sharing a link to a specific screen, the URL not open the screen, or the section, only the file.
It happened only with one file, with other files it’s working fine.
Any idea why it’s happening? I tried to see if there is any settings for the file but I couldn’t find anything.
Thanks!
  • 4925 replies
  • July 26, 2024
Hey @Wolf_Or, thanks for reaching out and sorry to hear you’re having trouble with linking to a selection!
This may be related to a bug our team is currently investigating:
How are you generating your link to the selection?
Wolf_Or
  • July 29, 2024
Thanks @dvaliao .
Just to be more specific - I’m not using the shortcut ⌘L, I copied the URL using the the button “copy link” .
The link is not even opening the right section… and it happed in a specific file.
I can also see different cases for this issue you mentioned in the community- some are using the button and some are using the shortcut. Seems like the problem is within the action itself and not the shortcut… any solution for that?
I also find this issue that might help to understand what is the problem - Links do design are missing node-id
  • 4925 replies
  • July 29, 2024
Hey @Wolf_Or, thanks for the additional context!
This is the exact bug we’re investigating. Links from the Share modal are not generating correctly to a selection. As a workaround, please generate your links to a selection using the shortcut instead.
