Library Color Appears Empty
  • November 21, 2023
  • 182 views
Hello Figma Community, have anyone faced this issue, we have a library and colors in there, and one of colors accidentally appeared empty though other files using same library see this color asset fine
Best answer by Ryan_52
Hi @Max_Turu can you try making a small change to that color in the library (for example add a small description) then publish the updates. Accept those library updates in a subscribed file and then return to the library and remove the small change you did and re-publish again.
If this doesn’t help please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Ryan_52
  • 382 replies
  • November 22, 2023
  • November 22, 2023
Thank you Ryan, that helped
