Layout grids not showing
Artur
Does anyone have an issue with layout grids not showing? It happened with 2 of my recent projects.
I set the grid up, use it across multiple frames on a page.
At first the grid works just fine but at some point they just cease to display.
Ctrl+G doesn’t work at all (as is going to the top “View” menu). This happens both on the desktop app and in the browser.
Best answer by tank666
There are a couple of reasons why a layout grid may not be showing:
https://help.figma.com/hc/en-us/articles/360040450513-Create-layout-grids-with-grids-columns-and-rows#Why_aren’t_my_layout_grids_showing?
If you think this is a bug, please report it to support: Submit a request – Figma
Mark_SB
  • April 16, 2021
Has anyone responded to you yet about this? I am having the same issue.
Artur
  • April 16, 2021
Nope, none at all.
Jeriah
  • May 17, 2021
Also having this problem. Sometimes if more than one wireframe is being used, the grids will only show on one of the frames and not the one that I have selected.
Leanne_Kolpin
We are also having the same problem with some of the icons we have made. No idea why this is happening.
  • 4870 replies
  • June 30, 2021
Maybe this will help someone:
Dm1try_R
  • July 10, 2021
Yesterday it worked, today it’s not. I guess it’s a bug.
  • 4870 replies
  • July 10, 2021
Anthony_DeCrescenzo
Same issue and the “reasons why the grid may not be showing” assume a certain ignorance on the part of the end users. Never a good opening posture and definitely a bad sole solution.
See this video for some grid weirdness.
  • 4708 replies
  • July 20, 2021
In this video it’s clear that you have some artefacts on the screen, this is a GPU-related issue that usually occurs on the per-file basis. You can copy-paste all your work into a new file from the corrupted one and it probably will be ok.
Anthony_DeCrescenzo
👆 Nailed it. Here was my issue and what I did:
  1. Copied all contents to new file (as per Gleb’s comment)
  2. No fix.
  3. Googled “figma gpu” and found a Mac-specific suggestion to disable auto-switching (which means GPU will now always be in use). As mine had always been disabled I wouldn’t have thought of it…
  4. …but there it was, enabled.
  5. Disabled auto-switch on GPU.
  6. Restarted Figma app and…
  7. Voila.
In case it’s a GPU issue for anyone else.
Thank you, @Gleb
Jasmine_Ke
Hey everyone,
I was also having the same issue and stuck because it wasn’t my GPU. However, I did realize when I had rotated my frame. the grid layout disappears. I would say try to make sure that your frame itself (not the contents within) are at 0 degrees.
Let me know if this worked for you! I’d love to know @goushiii on instagram
soheil
  • September 29, 2021
If you already have a component created with Auto Layout, make sure to document your auto layout settings, then remove Auto Layout. You’ll be able to see Layout Grid after that and then reapply your Auto Layout. That’s how I do it. It’s a pain, but I’m got it down
Remus_Baltariu
Yes, this can be the main issue if it’s not something hardware related (GPUs, memory, etc)
You have applied a rotation to the main/parent frame. If that’s the case, the grids will not show whatever you’ll do. Unless you create a new frame, or change the rotation to 0, of course 🙂
Hope this helps.
Corey3
  • October 12, 2021
I experienced the same issue and from the browser, if auto Layout has been applied to a frame, the Layout Grid option does not appear. After removing Auto Layout, then the Layout Grid option appears and can be used. There seems to be a conditional check on the frame, if Auto Layout is applied, do not display Layout Grid.
  • 4708 replies
  • October 30, 2021
This topic was automatically closed after 20 hours. New replies are no longer allowed.
