Kayeish
Large PDF exports even with compression plugins?
I’ve used many programs/apps and I find that Figma’s PDF exports are always so large—even after using plugins to compress them.
Example: Two page PDF document with only text, simple svgs icons, and two colours. No raster images, gradients, or effects. Super basic document.
  • Figma export 9.5MB
  • TinyImage compression 2.2MB
  • Compressify.io compression 2.2MB
I would expect this PDF to be no larger than 1MB in the first place. What is going on here?
The only possible factor I can imagine is the maybe the canvas size (1130x1600px), but I doubt it because everything in the PDF export are text/vectors. Any help?
Josh
Former Community Manager
July 24, 2023
Hey there @Kayeish, thanks for the feedback! We definitely know that our PDF exports could use a little work especially when it comes to optimizing their size. Some users have reported that using 3rd party tools outside of Figma have helped when plugins aren’t quite enough. For example if you’re on a Mac, you could open in Preview and then export again as a PDF to further cut down on size.
I know this probably isn’t ideal, but hope this helps. 🙂
Oh one other thing you could check within your file is to make sure your svg icons are flattened or as simple as possible.
Kayeish
KayeishAuthor
@Josh Thanks for the response.
I’ve used Preview and its Reduce File Size export and it’s still 2.8MB. I’ve used other third-party apps (Adobe) and none of them can get me lower than 2MB. This is actually quite an issue because of file upload restrictions are often set at 2MB for documents.
Do you know if the Figma team are actively working to resolve this?
Josh
July 24, 2023
Ah bummer that the workarounds aren’t helping in this instance. : /
PDF improvements aren’t currently prioritized but I’m happy to pass this feedback along to the team. Also I’d be happy to take a look at the file (if you’re able to share it) and see if I can offer any other suggestions to reduce the size.
Kayeish
KayeishAuthor
That’d be great, let me know how best to send to you for suggestions.
Josh
July 24, 2023
Feel free to PM me the file or post here in this thread. 🙂
Miek
July 25, 2023
@Kayeish
You can use our plugin, we do not export vectors and text as images, so the size should be significantly smaller.
However, we have not implemented any effects yet, like shadows…
MKitFPdf
Figma
Kayeish
KayeishAuthor
Thanks for the recommendation. While the PDF is very small with your plugin (53KB), the formatting is all messed up—thus making it unusable.
Miek
July 26, 2023
@Kayeish
The formatting should not be incorrect.
However, we cannot currently access the local fonts, so this could be the cause. You would have to define the missing fonts under “Fonts”.
Could you send me an example to test?
Kayeish
KayeishAuthor
@Miek I’m using Space Grotesk, which is natively available in Figma and not a local font. The formatting is all messed up, so I believe it’s an issue on your plugin end.
Miek
July 29, 2023
Thanks for the tip, yes there are problems with the “Space Grotesk” font, unfortunately it is not recognised correctly.
