I want to use also use tab-key to navigate trough the layers when select the same instance
vdekkernl
I want to add the same interaction (navigate to page) on the same instance that is nested in a component that is used on several frames.
Steps:
  • Select the component
  • Use option: Select all with the same instance
  • Hit enter to select all layers in the component
  • Use the ‘tab’ key to select the desired instance
  • Add interaction.
I need to this because I make components with several interactive instances in a separate library. And after making a lot of frames. I need to add a link on an interactive instance to one of the frames. Now I have to select all the same instances separate and add the interaction. This is time-consuming and a big possibility that I forget to link an instance.
Deno
  • August 26, 2021
Maybe some sort of “tab lock” in the given selection?
Regular tab switches siblings within a parent frame, but when selecting multiple layers we could “lock” the tab function to only work on the selected layers
  • September 25, 2021
