Hover effect (prototype mode) change elemetn X position
Carlos_Viciana_Martinez
Hello!
I’m creating a hover effect on a Pause medium but when I hover over the element it changes the status (all good) but it also changes the X position of the element so it’s not working as intended (it should remain centered). It might be something simple but I can’t find the solution.
Issue:
I can’t upload more images or a small gif as Im new in the chat.
Hope someone can help, thanks in advance!
Haroll
  • 273 replies
  • August 9, 2023
Hi @Carlos_Viciana_Martinez
You may want to look into Auto layout. It will help you align everything in the middle regarding their width
  1. Group all of your buttons (pause, load, settings and credits) in a frame (F)
  2. Turn that frame into an auto-layout (Shift+A)
  3. On the right panel you’ll find a section called “Auto layout” from there you can align the frame’s children to center
if you don’t want to use Auto layout:
  1. Select all of your buttons
  2. Check on the right panel you’ll find a section called “Constraint”.
  3. From there, click on the first option and choose center
Hope it helps
Thanks! I was able to solve it using constraints, regards! 🙂
ksn
  • 1673 replies
  • August 14, 2023
Thank you both @Haroll @Carlos_Viciana_Martinez
Gonna close this topic, but it will be available to anyone else who may have a similar question 😃 If anything else comes up, please feel free to open a new topic.
