Go to main component shortcut
My custom mac shortcut for Going to main component does not work anymore as it is removed from the toolbar. Could we please integrate some sort of keyboard shortcut for this? Seems urgent!
Best answer by Ryan_52
Thank you for your patience while our engineers worked on resolving the issue. We are pleased to inform you that the fix has been successfully released!
Please refresh Figma to ensure that you are using the fixed version.
RaphG
  • 6 replies
  • July 27, 2023
Same problem here - the functionality has disappeared from the menu bar, which means my OSX shortcut doesn’t work anymore.
Roman_Bartos
This was my most used shortcut in Figma BY FAR. I don’t understand how this 1. doesn’t have native support and 2. can be deleted. This proves that no one at Figma actually works in Figma.
Yump
  • 5 replies
  • July 27, 2023
Figma as a tool is amazing, but these type of small issues can be extremely frustrating- how did this change pass Q/A?
Does anybody know how could we set “Go to main component” to shortcut in this stuation?
I cannot understand why “Go to main component” has removed from meun bar…
RaphG
  • 6 replies
  • July 28, 2023
I’ve looked everywhere and there isn’t a native shortcut item for it - basically the “go to main component” action has been split in 2 (go to main component, go to main component in library), and neither are accessible in the menu (only as a button).
Ideally it should be called the same thing and added back to the menu bar as a single action, OR added as a native shortcut. It’s important that the shortcut is the same though, because it shouldn’t matter whether the component master is in the same file or not.
Christine_Oh
+100000 to this, please bring that function back or create a shortcut for this please!
Ryan_52
  • 382 replies
  • July 28, 2023
Hi everyone, thank you for raising this issue. Our engineering team is actively investigating the issue to determine its root cause and working towards a solution.
Ryan_52
  • 382 replies
  • July 28, 2023
Thank you @Ryan_52 and the Figma team for resolving this issue so quickly.
For those who are using a mac and are interested in creating a shortcut for this follow the following steps:
Go to settings > keyboard > keyboard shortcts > app shortcuts > Add Figma
Proceed to fill in “Go to Main Component” and a personalised keyboard shortcut.
The final result should look something like this:
