Figma plugin UI font family
Pedro8
I am developing a plugin for Figma, and I have been trying to modify the default font family that the UI uses by default, however, any attempt to force a custom font via CSS did not work.
I am starting to wonder if this is really possible.
So for trying to change the font family, in the ui.html file, in the section, I have something like the code below. I have my font file in a folder named “fonts” inside the plugin folder.
@font-face {
      font-family: 'myExampleFont-Regular';
      src: url('./fonts/myExampleFont-Regular.otf');
      font-style: normal;
      font-weight: 400;
.someSpanClassElement{
      ....bla
      bla
      bla...
Any tips, or confirmation that changing plugin UI font-family is not possible will be much appreciated.
  • 4873 replies
  • May 24, 2022
Your font must be on the Internet and be available via a link. So use Google Fonts or some other service, or upload the font to your site and link directly to the font in your CSS.
Pedro8
  • 9 replies
  • May 24, 2022
Thanks for your answer but this is not possible since this is a a private company-developed font…so unless Figma is able to fetch it from a private company server…getting it from the internet is not an option.
Still, it should be able to fetch if from local, feels a bit weird if not.
  • 4873 replies
  • May 24, 2022
Unfortunately, there is no other way. Plugins can only contain these 3 files:
  • manifest.json
  • code.js
  • ui.html
Images, fonts, scripts and other resources can only be connected by URL.
Pedro8
  • 9 replies
  • May 24, 2022
Good to know, very limited functionality from a developer point of view, but still good to know.
Thanks again for your answer.
Corey_O_Brien
I tried using Google Fonts and that didn’t work either. I get the following error.
Refused to load the stylesheet ‘https://fonts.googleapis.com/css2?family=Figtree:wght@300;400;600&display=swap’ because it violates the following Content Security Policy directive: “style-src ‘unsafe-inline’ ‘unsafe-eval’ data: blob:”. Note that ‘style-src-elem’ was not explicitly set, so ‘style-src’ is used as a fallback.
Any suggestions?
  • 4873 replies
  • December 24, 2023
resul_celik
I’ve added these two domains into the manifest.json and it worked:
"networkAccess": {
    "allowedDomains": [
      "https://fonts.googleapis.com",
      "https://fonts.gstatic.com"
I’ve been searching around for the last hour trying to get google fonts to work via @import url(). This did the trick for me. Bumping so others might find it. Thanks!
