Figma Mirror app doesn't render the design correctly
  • March 29, 2022
  • 69 replies
  • 7135 views
ahmad_tabby
When using mirroring on my phone, the design doesn’t show properly. Sometimes there are missing elements, or elements that are not fully visible.
This happens even when I open Figma Mirror on my phone’s browser.
Here’s how my design shows up:
I’m using the Samsung Galaxy S22 Ultra. Already tried re-installing the app and clearing the cache.
Best answer by John_L
Hi all,
We’ve pushed a fix that we think may help with the S23 issues you’ve reported. Can you let us know if things seem to be better or if you are still having trouble?
John
ahmad_tabby
  • March 29, 2022
Here’s another example with more elements in the frame:
omer_tzur
  • April 3, 2022
I’m also having this exact issue, this started happening right after I switched to the Galaxy s22 plus.
ahmad_tabby
  • April 3, 2022
Yea same for me. Worked fine on my Galaxy S21.
omer_tzur
  • April 5, 2022
I contacted Figma support about this, hope they can help us out.
Do you know if the problem has to do with android 12 or the new SOC?
lijie
  • April 6, 2022
Worked fine on my Pixel 6 with android 12.
I guess it just happen on Galaxy s22 s22+ and s22u.
lilinyang
  • April 7, 2022
I have the same problem with three mobile phones, s22+ ,xiaomi12 ,oppo find x5 pro
omer_tzur
  • April 8, 2022
So the problem has to do with the Snapdragon 8 gen 1.
In that case there are a total of 10 phones right now that are experiencing this problem.
Let’s hope it will be fixed sooner rather than later
Altamash_Shaban
Yeah!
Having the same issue on my S22 Ultra as well!
I hope it will be fixed soon.
eCraft
  • May 8, 2022
This bug still exists, any comments from figma side?
Rocio_Espinoza
I having the same issue with s22.
Vinizeras
  • May 13, 2022
Same here, Xiaomi 12 Pro 😦
Remon
  • May 15, 2022
I’m having the same issue with s22 plus.
TJ1
  • May 16, 2022
+1
Galaxy S22 and before this the S10e
Whole designs are wildly jacked up looking…especially ones with lots of elements/layers.
Hitesh_Tibrewala
Same here using the S22U (8 Gen1 variant)
Rodolfo_Calvo
Here it also doesn’t work properly on my S22 Ultra. The annoying thing is how long it takes Figma to fix this.
Kushagra_Sharma
This is an issue with Galaxy Tabs8 ultra as well. Works well on my old phone but doesn’t render on the latest device on market
Jesper_Klintestam2
Yup, same on Tab S8+. And the problem is also in the browser, so I can’t even work on stuff.
ahmad_tabby
  • June 2, 2022
Hey @omer_tzur, did you hear back from Figma support? Do they have any ETA on the fix?
Yariv
  • June 8, 2022
Having the same issue on my s22 - really annoying…
I had a Xiaomi T9 - worked perfect. Its really weird that on a newer device which i believe has much better rendering abilities, it doesnt work properly
Guilherme-Fidelio
Same problem here on a newly bought Samsung S22, an update about a future fix would be helpful
TheQuatum
  • June 14, 2022
Can we get an update on this Figma? This big completely renders an entire generation of phones useless and I’ve had to switch to an older phone just to design. This is a major problem that needs clarity
Mohamed_Karan_Ubaidi
Exact same issue on the S22+. Worked perfectly fine on the OnePlus 9RT.
TheQuatum
  • June 17, 2022
Unreal. I literally can not use an entire generation of devices because Figma refuses to render on all Snapdragon 8 Gen 1 devices I’ve tested. I now have to downgrade my phone just to use Figma which is a significant issue as I now can no longer have any of the phones I actually wanted.
Bilancio
  • June 23, 2022
Same issue, but I’m using an iPhone 13 Pro 😦
Kamran
  • June 23, 2022
Same here. I’m using a Samsung Galaxy Tab S8 and it doesn’t display all the elements. Tried to understand if it’s based on type of element, but it’s all random what it actually shows on the tablet. In the menu it says : “Mirror - Loading…”. Can someone from the Figma team confirm if there is any work being done on this?
