Draft file suddenly turned into view only
Dishi_Sen
Hi,
So I was editing a draft file and it suddenly turned into a view-only file. Although I am still the owner of the file I have no rights to edit it nor does the edit option show up on trying to share it.
Does anyone have any clue what happened?
Ward_Meremans1
Are you using the free version of Figma? Because you can only have 3 private files.
  • 4710 replies
  • May 22, 2022
@Ward_Meremans1 that’s very incorrect information.
Here is a similar issue, check if maybe something like this happened, and if not reach out to Figma support, the forum is not the place for such bugs.
_Brendan
  • August 13, 2022
Same thing just happened to me with two different drafts… 💩 💩 💩
James_Kelly1
We are having an issue with a file too. I’ve shared with someone with Edit access, they started editing the file and now suddenly after rebooting Figma they can view-only but they are admin of the team
Not sure how to get them back to edit access as the permissions are set correctly to ‘admin’
Carla_Stanislav
I had an issue very similar to this, but in my case an icon with “Anonymous” appeared as well next to my user. This is really weird as I am the only one on the account, and I haven’t shared any of my files with anyone. However, the issue sort of fixed itself, the files are ok now… I did change my pass and enabled two factor authentication though…
it’s just happened to me I’ve lost about 80% of my work and what is left view only 😡
AddWeb_Solution
Hello,
You may have accidentally logged out of your Figma account. If you are not logged in to Figma, you will not be able to edit any files. Make sure you are logged in to your Figma account.
Another issue could be Someone with edit access to the file has changed your access level to view-only.
Fabian_Vzla
I got the “view only” in more than one file, that I created, and I’m the only one on the “team”, the owner. But now, not only I can’t edit, but My user appears twice one with the view permission and the other as the owner.
Try closing the file and opening it again from the Home > Drafts section. It worked for me.
Henry14
  • February 15, 2024
This is bad man. I lost all my work. It went to view only 😡😡
