Disabling parameters in nested components
  • October 3, 2022
  • 19 replies
  • 2950 views
ChiefS
I think that’s the new feature “nested components” need to be more functional. For example: I have a card with nested component button. But the only parameter that i need to edit is icon on this button, all other settings useless in this component. I thinks it will be cool if i can disable some of nested component’s paramters like show icon or btn size and leave only icon-type parameter. And it will be more cool if i can make preferred icons for nested component (in this card i can choose between filled like or unfilled)
  • October 3, 2022
  • January 1, 2023
GraceSong
  • August 10, 2023
It would be really handy to be able to hide not all but some irrelevant nested instance properties on parent components, e.g. hide property for interaction states on a nested instance so that it won’t appear on parent component. This is for use cases where the specific property would need to be set at a parent level (larger component holistically), rather than solely for the nested instance.
Claudio_Fresta_Suharno
bumping this up. similar thing with this thread (but unfortunately, it’s closed) Disabling parameters in nested components
Harshika_Jain
Is it possible to give the users the option to show only one icon/ boolean prop at a time? I want to have the option to show either or, but not and
Tony_Ke
  • December 12, 2023
Same here. Would like to have this feature to organize nested variants.
Carioca_Andre
  • February 10, 2024
keeping this alive, so Figma adds this fature
Henning1
  • February 23, 2024
Same as here. All the nested components makes it real unclear what i can change.
I want to focus on the changes of specific components, not all.
Thanks a lot for implementin!
  • Figmate
  • February 26, 2024
Hello all, Thank you so much for sharing your feedback with us! We truly appreciate it and I’ve shared it with our internal team for future consideration.
I understand how this could be handy for our community members. Please don’t forget to vote up this idea (Vote button above the topic’s title ☝️)!
PatJW
  • March 1, 2024
This would be a great help for organizing atomic design components. Our design kit has a lot of modular fields (e.g. text fields that could have leading icons, trailing icons, headers, footers, etc. in any combination) and making a component for every possible combination defeats the purpose of using these properties to begin with.
Either this, or the ability to inherit properties to the top-level component so that I can reorder them in the list in a way that makes more sense.
Nik3
  • April 17, 2024
Yeah we totally need this feature too to make things for our designers more easy. E.g. I have a very powerful Text Input component that could be used for inputs, textfields, dropdowns etc. but to make the component easy for the designers, I have to detach those and make specific changes to remove the settings because I want a specific combination of the powerful component to be fixed and only a view parameters to be “editable”.
Elaine_Cervania1
Yes please.
Connie5
  • August 28, 2024
reupping, with added request for the ability to order/reorder the nested variables
Piotr_Stanislawski
Bumpin’ that 💚💚💚
I urgently need this
Apolline
  • September 4, 2024
Why isnt this thread merged with https://forum.figma.com/t/expose-hide-nested-instances-at-component-property-level/30052 which has 650 votes and is one of the most popular topic in the forum ?
Workplace_Julius
Yes please and thank you
User_One
  • September 11, 2024
I want to be able to disable some variants from publishing without having to remove those variants from its parent components.
Caro4
  • December 4, 2025
Are there any news here? This is 3 years old. Did anybody find a workaround?
I am having unnecessary long property panels even though I decluttered components. This is quite confusing for library users and not very good for consistency. I am currently using a lock emoji to indicate that this property is not to be changed… not very professional.
lea_dvn16
  • March 24, 2026
+1 I really need this please
