Detaching variable should first revert to alias, then to hex code
owen5
  • 8 replies
I have set up a design system with a core color ramp of 10-step color ramps, for example, blue-1 to blue-10.
I then assigned those steps as aliases to semantic variables that I use to define the states of various components. For example, I create a semantic variable for button-hover, and assign blue-6 as an alias.
I would like to be able to detach one of my semantic variables, but preserve the alias. So when detaching the color variant ‘button-hover’, the variant reverts to ‘blue-6’. rather than the hex code Then if necessary I can detach again to revert to the hex.
Current behavior:
  1. Detach variable with alias from layer
  2. Layer reverts to the hex code
Desired behavior:
  2. Layer reverts to alias variable
  3. Detach alias from layer
  4. Layer reverts to hex code
anoldasgupta
Completely agree with you… otherwise what’s the point of creating alias at first place…
Alias name should come first then the hex code.
  • November 1, 2023
