Can't use variables to create a percentage on Letter Spacing
Phil_Larsen
I use percentages in a project for the letter spacing. I can’t use variables to achieve this value. It always defaults to pixels.
  • 2545 replies
  • April 19, 2024
Thank you for providing feedback! I will share this with our internal team. Your input is highly valued, and we will take it into consideration for future enhancements.
Stan5
  • 36 replies
  • April 19, 2024
What unit is currently used? I tried converting the percentage to REM but the text shifts when I assign the variable, so REM clearly isn’t the right unit.
Phil_Larsen
  • 130 replies
  • April 19, 2024
It defaults to pixels on Letter-Spacing. I tried using a decimal but then it was just a decimal of a pixel.
This issue is also present on line height.
pinquitte
This is weird 😦 I cannot use line-height variables for our “label” text style because of this issue. I need to add 10% as a value, but % character is not permitted.
Actually, this problem exists since 2021… Any news about it? Thank you very much.
Jeremy_Knudsen
I just ran into this problem. What good is having a variable scoped to line-height if it ONLY supports a px value ??
Ed_Kolan
  • August 1, 2024
Same issue. Cant setup negative 2% or value 😦
kiprou
  • 14 replies
  • October 4, 2024
If pixel values are considered “number variables” then percentage values should be considered number variables too. Please get this fixed.
Emanuel-Mardsjo
I’d just like to add to this as well. Would make it a lot easier to set up consistent styles.
Shiv
  • 10 replies
  • February 6, 2025
Just wanted to chime in here and say that this is absolutely required for us as well. Not being able to use tokens for letter-spacing is a gap in our design system that we want to address as soon as possible.
@y_toku are you able to confirm if this feature is being worked on?
Felix_Dorner
Variables where we can set the unit (either percentage, em, rem, etc.) are soo much needed. I can’t add percentage-based letter-spacing or line-heights which is basically the norm in web design.
Ishara Induranga
I’m trying to use percentage values like -2% for letter spacing in Figma, but it doesn’t seem to work. When I set it using variables, Figma defaults the value back to pixels. Just wondering does anyone know if there’s a workaround
Jeremy_Knudsen
Came back almost a year later to see if this has been fixed. Nope.
Marc Hauser
  • July 25, 2025
It’s 2035, still not fixed.
