BUG (FIX LAUNCHED): Deleting layers directly on panel doesn't work
emily
Hi everyone! For some users, the issue has been fixed by upgrading to the newest version on Chrome.
Can you try upgrading to the newest version and check if the same issue occurs? (The newest is Version 124.0.6367.93 at the moment).
Here is an article how to Update Google Chrome - Computer - Google Chrome Help.
  • August 2, 2024
Hi guys, this has just started happening to me today. I can use delete, and copy/cut/oaste from the main artboard but nothing from the layers panel. I can do it no worries in the DT app but just not on chrome, disabled ALL extensions and even tried a new profile but issue persists.
Please help
Moira_Dela_Cruz
Hello. I encoutered this again just today @emily Same problem. Already updated my chrome but still won’t work
ksn
  • 1768 replies
  • August 5, 2024
Hi all - since you replied on a topic from May, I’m reopening a new one.
At that time, updating Chrome addressed that problem. I went into Figma, and was able to delete layers as expected.
I’d like to have you all verify some info, so I can create a bug ticket:
-Is it only Chrome you have issues with?
-Does it happen on the desktop app or another web browser as well?
can any of you grab a screen recording of when you try to delete the layers panel?
Moira_Dela_Cruz
Hi @ksn
Yes, I’ve tried it in microsoft edge and it worked there but couldn’t with Chrome. I also tried with my other Chrome accounts but still the same problem
It works fine on the app. Just the (Chrome) browser is the problem
  • August 5, 2024
Updating Chrome has not done anything. I have tried with and without extensions (diff profiles)
-Is it only Chrome you have issues with?-
Tried it on app and safari and zero problems, its just Chrome
It works fine on the app. Just the (Chrome) browser is the problem, i also tested it on Safari and it works fine.
ksn
  • 1768 replies
  • August 6, 2024
ty both! I just added this info to a bug ticket – just another qq: are you both on VPNs?
I’ll send another message when I get an update on my side.
Michal_Hlivka
Hi I have the same problem.
-No delete or backspace button works when selecting from layers.
-Works fine when I select the object directly on board
-I am using chrome and VPN without extensions
-Works fine in Edge
-Restarted and cleared cache but no help
Many thanks in advance for Fixing this.
ksn
  • 1768 replies
  • August 9, 2024
Thanks @Michal_Hlivka - if you have a sec, can you verify if you turn the VPN off, does that help at all?
Bm_Ashik
  • August 13, 2024
Thank you for remembering me!
The problem on the web, layer delete and copy-paste problem
ksn
  • 1768 replies
  • August 13, 2024
Hey @Bm_Ashik - I merged your post over to this topic. Can you take a look at the above posts + try the suggestions mentioned? Let me know how things end up (if anything helps, or it still doesn’t work).
I also can’t copy/paste, or delete from the layers panel for the last two days using Chrome. This is disrupting my workflow hardcore and working in Safari is not ideal for the long run. Is there still no solid solve for this issue?
Still cannot delete or using backspace from mac using latest chrome update.
Please help to fix it
Bm_Ashik
  • August 14, 2024
Thank you @ksn !!!
After using it for some time, the problem appeared, I also can’t copy/paste, or delete from the layers panel. So now I use the app.
Michal_Hlivka
Thanks for looking into this @ksn, it really disrupts the workflow.
It seems that indeed the VPN is to blame.
I could not test on the same computer, as my company prevents access to internet outside VPN, but I have tested it on the same account and same internet connection.
On my personal computer it was indeed working fine without VPN.
Also on my work computer , using VPN, it works on the first frame I select. However, after switching to another frame, it stops working anywhere.
So I can delete the layer on the first frame I use (any frame), and then once I use another frame I cannot use it there, or back at the first frame.
Also its not just delete, but any keystrokes on ay layer selected in layers panel.
If the layer was selected directly in the viewing pane, it works just fine.
But its often difficult to select the right layer there. 🙂
  • 4 replies
  • August 14, 2024
I noticed this problem since today as well.
My system:
  • Ubuntu 22
  • Chrome 127 (latest)
  • Figma in browser
I can’t perform any shortcuts anymore when a layer was selected through the layers panel. No delete using backspace, also no copy-pasting shortcuts.
When performing these actions on a layer I selected though the artboard, it just works.
Also, switching to Firefox the layer panel in combination with shortcuts just works.
ksn
  • 1768 replies
  • August 14, 2024
Thanks for the info – I’m going to add this detail as something that could be a factor on the ticket that is open!
For anyone else - can you please confirm if you are on a VPN, and if so, does turning it off seem to help?
ksn
  • 1768 replies
  • August 14, 2024
Quick update:
Our engineering team thinks this is related to another issue we have involving Chrome shortcuts. Still looking into it, but making progress! Will update again when I can.
ksn
  • 1768 replies
  • August 15, 2024
Hello all! I’m letting you know that our engineering team pushed out an update that should have fixed this. Can you please let me know if you still have trouble with the layers panel?
Please make sure to quit and restart Chrome first to make sure you have the latest updates set.
Kerry_Kao
  • August 15, 2024
It’s working! I had this problem for over a year! It’s finally working. Thanks team 🙏
Moira_Dela_Cruz
Mine is working now but encountering a different problem in both app and website. I cannot seem to rename layers properly by dragging my mouse to change a word or letter it won’t highlight select the word i’m trying to select.
  • 4925 replies
  • August 16, 2024
Hey @Moira_Dela_Cruz, sorry for the trouble!
This is indeed a new bug that the team is already investigating and working on fixing. Please follow the topic here for updates:
Moira_Dela_Cruz
hey @dvaliao the renaming issue works now but the previous issue (editing in layers panel) doesn’t work AGAIN. This is on website
  • August 19, 2024
Hello @dvaliao
This still doesn’t work for me, do you have a solution to offer me? My Chrome is up to date and I have restarted my computer several times.
  • August 19, 2024
Yes the renaming now works but you still cant delete layers within a frame?!
Wolle
  • 10 replies
  • August 19, 2024
Same here. Figma in latest Chrome. No VPN.
