Bug Auto Layout and components overflowing containers
Mojo
Anyone else having this bug, where things you paste, or randomly-based, overflow the container?
Every time y paste things auto layout seems to behave the worst way possible.
And as soon as you double click the component or break it, it gets fixed.
Se Video for reference pliz 🔗
JosephxBrick
  • 67 replies
  • October 10, 2022
Hi! Auto-layout has been very broken for a while now. The symptom I see most often is “fill container” not filling container, and I’ve seen three things that cause it, though not every time:
  1. changing auto-layout direction from vertical to horizontal or vice-versa
  2. changing a component instance to a different variant
  3. accepting updates from a library change (for component instances with auto-layout)
The third is by far the worst, as it can essentially break any instance’s auto-layout anywhere on the page. I’m forever finding broken auto-layouts. If it’s in an instance, usually double clicking on the offending layer fixes it. If it’s not an instance, you need to select the broken layer, change it to Hug or Fixed, then reset it to Fill.
The Figma folks are surely aware of this bug. It’s impossible to use auto-layout on a regular basis and not see this happen.
I wrote a script (to run in the Scripter plugin) that fixes this (at least temporarily) for all objects on a page or in the current selection. I run it before presenting any design.
Julio_del_Rio
I’m having the same issue, it’s super frustating and it also breaks when you update any component inside that parent component. I’ve seen it occurs mostly with text elements with “fill-container” value
I hope they fix it soon, it’s impossible to work fast with this issue.
note: to avoid double clicking on the components try cmd+click on the text that’s causing the overflow.
Mikhail13
  • 11 replies
  • October 31, 2022
Same problem, and every day got more and more objects broken 🤬. First results of Adobe buy Figma? 😂
Mikhail13
  • 11 replies
  • November 8, 2022
Figma still ruins filled objects. Thanks to @JosephxBrick for the script.
Mikhail13
  • 11 replies
  • November 9, 2022
@Figma_Support I’m gonna report every day till this bug would be fixed. Bug is extremely annoying, so why I can’t be so? 😂
Daniel_Rothbard1
Bumping this.
My entire team has been running into this bug a lot. It also appears in Prototype view which makes user testing a pain.
Workaround:
For some reason you just need to select the object that is broken to fix (as shown in the loom video)
An easy fix is to just select all the elements with a page and hit “enter” as many times as needed to get to the bottom-most component. That should fix all the fill wonkiness within the page for a little bit.
Friend
  • December 9, 2022
Has anyone heard anything new regarding this bug? It’s extremely frustrating! There are also other components with ‘fill container’ that turns into ‘fixed’ when used elsewhere. Here the double click-thing doesn’t work at all, no matter how many things I try. These bugs make it really hard to use and develop the system that I’m currently working on.
Mojo
  • 67 replies
  • December 9, 2022
Seems like figma went radio-silence on this
Friend
  • December 9, 2022
@Figma_Support a status update on this would be highly appreciated! <3
Mojo
  • 67 replies
  • December 20, 2022
if you guys can report the bug on figma, I did, here is how https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report
Mojo
  • 67 replies
  • December 20, 2022
Quick fix that is working for us ATM, grab all those screens (frames) that are causing troubles.
1 - Hit command + X
2 - Hit command + V
3 - command + Z (until you revert the pasting and cropping)
Last step is to prevent you from loosing prototype connections, or frame links losses
In my case I grabbed all the sections (Shift + S ones) and cropped. them with the same technique detailed above ^
Rockytori
  • December 23, 2022
@Figma_Support This is a very frustrating bug, please for the love of everything, find a fix for this. Every time I publish a library that’s being used by dozens of designers across different teams, I stress the heck out as it gives me 0 confidence that my update won’t cause breaking changes.
Mikhail13
  • 11 replies
  • January 10, 2023
@Figma_Support, bug is still there, omg, almost 4 months of pain
BlakeLoomis
@Figma_Support I’m also running into this problem pretty regularly. Could this group please get some acknowledgement that the issue is being noted by Figma? I understand it may take time to fix and there are likely other priorities. Just acknowledgement that it’s been noted would be great, thanks! 🙏
Friend
  • January 30, 2023
It’s crazy to think that this is an industry standard piece of software, and yet there’s not even a reply. And it’s not just here. I’ve seen similar threads on it. No reply.
Olivia2
  • February 21, 2023
I’m still having this problem - has there been any work arounds yet? pills are breaking in client presentations… not good
ChiefS
  • March 6, 2023
Bug is still alive @Figma_Support , guys, please, do something
Mikhail13
  • 11 replies
  • March 8, 2023
@Figma_Support, bug is STILL there
Luiza_Ramos
Bug is still here! What is the priority in the backlog to fix this issue?
Mikhail13
  • 11 replies
  • April 20, 2023
Katie14
  • May 3, 2023
My team is still experiencing this as well. While our design team has the patience (for now) and Figma prowess to fix it, others within the company are not receiving it as well.
Mikhail13
@Figma_Support BUG. STILL. THERE.
Bengt_Lange
@Figma_Support please Fix asap. It’s annoying!
Tooba_Waqar
@Figma_Support can we have an acknowledgment here ATLEAST? Like working on it / sorry for the inconvenience? What’s taking so long to address for a software that’s meant to help others solve complex design problems-
Mojo
  • 67 replies
  • June 8, 2023
What it can help is, as I mentioned before guys, open a support request, it will be way faster. Bug Auto Layout and components overflowing containers - #11 by Mojo
The more they stack, more visibility to the problem
