[autolayout] When switching from horizontal layout to vertical, vertical resizing should be set to "hug" instead of "fixed"
  • July 11, 2022
  • 1131 views
Ruth_Thomson
Say I have a 3 column design that has vertical resizing set to “hug”. When I switch it to vertical layout, (so 3 rows instead of 3 columns), the resizing is set to “fixed”. This is frustrating because it means I have to manually get to each layer and manually change it as it always leads to overlapping layers. I can’t really see a use-case for wanting “fixed” vertical resizing for auto layout when it’s set to vertical.
Here’s an image to demonstrate. As you can see, when I switch to vertical resizing, the outer frame becomes too small and doesn’t hold all the content, which almost always requires manual tweaking afterwards
  • October 9, 2022
