Applied variables get detached
Hi! Anyone else having an issue like that? I’ve set a top-padding and bottom-padding variables. I select an element, apply these variables, and it seems ok. Then if I deselect and reselect this element, paddings have lost the variables, and there are just raw numbers :frowning_face:
It all started, when I played with the Number scoping in variable settings modal. No matter what settings I check there now, it won’t work anymore. But, if I set these variables to different values, it sometimes works. Really weird and annoying.
Ok, false alarm. Found out that variables are still attached. Don’t know why, but in the UI the values are visually styled like raw numbers, not as variable values. Case closed.
