Slava_Bronevitskiy
Aug 19, 2021 3:10 PM UTC
Z-index property that is independent from Auto Layout
Currently there is a huge limitation in prototyping possibilities because any dropdown menus appear underneath the following element in the autolayout flow.
I can’t remove autolayout because it would break designs across all useage of design system components and we can’t properly demo prototypes. Anchored by the lack of a customizable z-index property.
    Constantine_Zuev
    Dec 10, 2021 9:21 PM UTC
    Explicit Z-index property has its pros and cons. For a start, it is going to be a mess. Even more a mess if you are using libraries. It is just too easy to abuse. I know same problem exists in CSS, where you often spend hours trying to figure out why something is not in a place it is supposed to be. I would rather see some entirely different way to solve “pop-up” problem.
    For example, ability to position overlay relative to interactive component that invokes it.
    Here is my quick mockup:
    What do you think?
    Roger_Junior
    Dec 13, 2021 12:08 PM UTC
    I think this would help but won’t solve the problem.
    For tooltips, for example, we wouldn’t be able to change the text for each tooltip without creating multiple frames outside our main frame. In this case, it would be best to have the button and the tooltip itself in the same component/frame and adjust the z-position manually.
    h.rude
    Dec 14, 2021 12:42 PM UTC
    I agree, this would also help for the workflow on my end.
    In general having overlays is a problem when using auto layout. So I am always have to find a good combination of contraints with no autolayout and autolayout.
    Especially when on hover the hovered element is bigger and maybe even overlapping with items on the left or right, setting the z-index would help a lot!
    Currently I have to move these kind of hover-overlays out of the variants canvas to make it work via interaction “open overlay”. This adds again some confusion when it comes to a handoff (to Devs or other Designers). Because suddenly not all states can be found in the variant area.
    James_Mitchell
    Dec 18, 2021 9:17 AM UTC
    I wrote a small plugin that can reverse the z-indexes in an auto-layout.
    It makes use of a hack using flips and reordering that was mentioned in another thread so a native solution would definitely be preferred, but for the time being this should help when you really need it.
    Figma
    Matt_at_HAUD
    Dec 23, 2021 12:24 PM UTC
    Cool, it does its job, quick and easy. 👍
    Hey, @James_Mitchell could you maybe rename this to something more descriptive? Like, ‘Reverse Autolayout Z-index’, for instance?
    I can’t quite wrap my head around the fact that plugin names are so much out of the blue sometimes. 🙂 Like, good luck finding some plugins after a few weeks of not using them, then recalling ‘Ah, there was this great plugin I need for that’ and then you stare at that list, completely lost… 😅
    James_Mitchell
    Dec 30, 2021 1:31 PM UTC
    @Matt_at_HAUD I’ll have a think. I chose Easy Z because typing ‘ez’ as a quick action returns it as first result, whereas ‘Rev…’ matches too many other things.
    If I can’t think of a suitable name I can anyway add a label to the command to make it more searchable / clear.
    eruveo
    Aug 1, 2022 5:09 PM UTC
    An absolute position has been implemented recently.
    Screen Shot 2022-08-01 at 7.08.17 pm
    ryanleichty
    Oct 7, 2022 4:36 PM UTC
    Just ran into this problem. +1 for a z-index property (though I can’t imagine the potential mess/complexity this’ll introduce)
    Arvid
    Nov 10, 2022 4:50 PM UTC
    Aaaaand today again I have an issue that would really profit from a change to this behaviour 😦
    Alina_Trussova
    Dec 1, 2022 5:46 AM UTC
    Are there any updates on this topic? I also came across this problem.
