SOLVED - Preserve Scroll Position (please roll back the feature)
Show first post
Right – and all previous prototypes are retroactively broken. Lovely.
I don’t name my frames the same thing, I usually name them after the interaction that took place in the prototype and name the section after the feature.
Brian_Warren
This has really thrown a big wrench into my workflow, which I have yet to be able to solve even with all of the renaming suggestions.
I have built a large scale component library with page templates all using the naming conventions for component categorization (frame name ex. “Popup/Basic CTA”)
Ever since this update, when I try to use one of my popup components as an overlay on a page (frame name ex. “Home”), this interaction resets scroll position to the top of the page.
I’ve tried simply renaming the page and popup overlay frames, and this does not work for me.
Previously, all I had to do was check the box. Easy.
I could be doing something wrong here, but in my mind this issue is NOT SOLVED and I have no idea how to rename my entire library to make this work.
nikolasklein
Hey Brian, I’m not sure I fully understand your setup and where you’re running into issues.
  • Are you linking to a popup with an “Open Overlay” interaction and that resets the underlying scroll position?
  • Or are you linking to another frame with a “Navigate to” interaction and it resets the scrolling there?
When you said you’ve tried simply renaming the page and popup overlay frames, I’m assuming it’s the later. Any way you could send me a screenshot of the file so I could take a look? Thanks!
Jefferson
Ridiculous from Figma, but your solution works. Thanks!
Truman_Halladay
This needs to be higher! Your artboards need to have the same name. fixed this issue after spending hours doing everything else
Aysel_Malikova1
I found a solution, maybe it will work for you too. My layers were auto layout frames. I converted them to a standard frame. (right click - frame selection) and it’s done 😃. It doesn’t jump to the top of the page anymore.
Yann2
  • November 8, 2024
Nah this is CRAZY! It took me one hour to debug this and your solution works.
People here talk about the top layer having to be the same. Whatever that means. Just call it artboard ffs…
I literally duplicated my artboard and everything had the same name. Yet it didn’t preserve scroll. But as Figma automatically renames my new duplicated artwork, everything breaks.
Dear Figma team: I love you. But this needs to be fixed.
Nellya
  • 648 replies
  • November 8, 2024
You can uncheck automatically renaming here
LeosimoesHearst
I have the same problem that i cannot solve.
Always jumping on mouse over.
Awfull.
We need some fix on that
