Toby11
Nov 28, 2024 11:37 PM UTC
Slides: Copying slides into original template creates duplicate template
Some quick context: I recently created a basic Figma slides template. After using the template & theme to create an actual presentation, I identified some new slides that I would like to include into the original template.
When copy pasting the slides that used the template into the original template file, it created a duplicate template with the same name for the slides that were pasted in, even though they used the original theme of the template.
The main issue I have here is that when swapping the template to the original, it randomly shuffles the colors. So I have to adjust the entire slide.
I feel like updating templates over time based on real usage is pretty common, and the current behavior makes it rather awkward.
Thanks!
Margot_Gabel
Jun 10, 2025 10:41 AM UTC
Running into the same issue daily as we always copy paste slides from other documents, ending up with many duplicate and ‘custom styles’ which you can not even delete unless you change all the slides that have this style.. .Style managements is super cumbersome in Figma Slides at the moment.
Using Figma since 2018.
Tom Reem
Jun 11, 2025 8:36 PM UTC
Hey ​@Toby11 and ​@Margot_Gabel, appreciate you both surfacing your experiences here with regard to adding slides from other documents.
Following up here — I checked in, and the product team is actively tracking this request. While I don’t have a timeline to share just yet, I’ve added your feedback to the project and highlighted how preserving template styles (like color) would save time and reduce the need to rework anything you’ve already created.
We’ll announce improvements to style management in Figma Slides via our Release Notes. Feel free to reach out if anything else comes up in the meantime — we’re keeping an eye out on this thread. 🙏🏻
Patrick_Cusack
Dec 2, 2025 7:51 PM UTC
I'm having the same problem here. The way I have my slides set up is that I have a single master file that I publish as a template. I then construct various decks from it. What I've noticed is happening is when I bring in a newly published template into one of my existing decks, it creates a duplicate template style, which is very frustrating because it's coming from the same template, just one that I've updated. I wouldn't expect a duplicate template style to be created. It's impossible to remove the duplicate without deleting the slide I imported. It's very badly implemented and I'm very frustrated.
Margot_Gabel
Mar 30, 2026 1:00 PM UTC
Average Slide deck here 😭:
