Shelene_Lee
Feb 24, 2021 6:01 PM UTC
Show Font Weight in Inspect panel
When inspecting the following component, I can click on the font to see the font weight and style in the inspect panel. When my dev clicks on the same item, he does not have all the CSS information that I have in the inspect panel, specifically he is missing font weight and font style. He does not have the ability to see the different font weights, which is unacceptable. Is there some way to fix this?
Component with my inspect panel:
Screen Shot 2021-02-24 at 10.12.33 AM
My (designer) Inspect panel:
Developer Inspect Panel:
✏️ Note from the moderator
There is a way to see the actual font weight, but it’s hidden and inconvenient: Show Font Weight in Inspect panel - #5 by Gleb
Logan
Aug 18, 2021 4:05 PM UTC
We are also experiencing the issue where developers are not seeing the correct font-weight when using the inspect panel. You can see that the font-weight is listed as “normal” which will not render the proper style of the font (bold) if used.
Inspect in Code View
Screen Shot 2021-08-18 at 11.01.53 AM
Inspect in Table View
Screen Shot 2021-08-18 at 11.03.25 AM
mmcdaniel
Aug 20, 2021 3:56 PM UTC
Yeah I don’t know! It’s also weird that in the code view it’ll show “identical to … 120%” but then show 101% on the duplicate rule shown in the table view.
This also shows up with different font sizes. e.g., 14/20 showed different percentages and they still didn’t match.
Shuaiqi1_Wang
Aug 23, 2021 1:06 PM UTC
I think this is a serious problem. Using the same font file, the problem only occurs in MacOS.
Tiago1
Aug 31, 2021 6:57 PM UTC
No news?
linkus
Sep 3, 2021 2:27 PM UTC
I’m amazed this bug still was not fixed. We too have actually had to adjust our dev handoff process (which adds a lot of hours) to be able to work with this bug…
coolemur
Sep 3, 2021 3:12 PM UTC
Some details about this issue:
Figma shows:
Table view: Font style: Regular
Inspect view: font-weight: normal; (correct)
Typography: Weight 400 (correct)
Table view: Font style: Medium
Inspect view: font-weight: normal; (should be displayed as font-weight: 500)
Typography: Weight 400 (should be displayed as Weight 500)
According to Font Weight and Contrast: (just google “font weight regular in points”):
font-weight === typeface weight
400, regular === Normal, Regular
500 === Medium
Conclusion: Figma doesn’t detect medium fonts correctly.
Tal_Engel
Sep 7, 2021 8:15 AM UTC
Same problem here!! Any idea when this will be fixed. Any comment by a Figma representative? This bug creates problems with handovers to our devs.
Figma team, please fix this !
_Hal
Sep 9, 2021 1:47 AM UTC
We also encounter this issue, the workaround is asking developers to install this font on their computers.
Mike_Peng
Sep 30, 2021 9:48 AM UTC
Same issue here, this is a very serious issue, please fix it.
Victor_Uvarov
Oct 5, 2021 7:52 PM UTC
Same problem here
