Oleg_Vasendin
Nov 13, 2023 12:41 PM UTC
Save the shortcut to the desktop
Hi everyone 👋
With each update of Figma, which occur quite often, the shortcut is removed from the desktop. This is annoying and makes me waste time trying to create a shortcut again.
The desktop is my workspace that I manage. The program should not perform actions without warnings, such as creating or deleting something. It is correct to create a setting or dialog box that allows you to manage shortcuts if it is really important.
It will be great if the Figma developers fix this.
Hug 🤗
Gayani_S
Nov 14, 2023 12:36 PM UTC
Hey Oleg, thank you for your feedback! Please make sure to upvote this.
Patrick_Nelson
Jun 20, 2024 6:54 PM UTC
I think this appears to happen to me on every single update, actually. @Oleg_Vasendin, by chance do you happen to be 1.) on Windows and 2.) naming your shortcut exactly “Figma”?
If so, then I wonder if maybe this can be bypassed by naming it something different, like “Figmaaaa”. 😅 I think I’ll give that a shot.
Patrick_Nelson
Jun 20, 2024 6:58 PM UTC
p.s. @Gayani_S this might be more properly classified a bug. For example, if the Figma app (upon installation) doesn’t add a shortcut, why does it delete it? Or, if it removes the old shortcut (because it is understandably outdated if it installs to a new location), then why does it not add a shortcut back?
Also, my rename approach could work even if the install location changes; at least on Windows. The reason is because Windows will automatically update shortcuts if/when the file they pointed to changes (not sure how though, seems like magic to me).
Oleg_Vasendin
Jun 20, 2024 9:40 PM UTC
Hi @Patrick_Nelson! This is exactly the way I ended up using to fix this annoying behavior). So yes, renaming the shortcut helps, but I had to get this experience before resorting to it.
Gayani_S
Jun 21, 2024 9:09 PM UTC
Hey @Patrick_Nelson, apologies, yes this does sound like an unexpected behaviour, thanks for the explanation! Please feel free file a bug report. Our team can investigate further on this issue and give you more insights.
Thank you for your help.
Patrick_Nelson
Jun 22, 2024 12:24 AM UTC
Alright, done. Thanks for the convenient link.
