Bryan_Berger
May 19, 2021 4:06 PM UTC
Reference a branch in another library
First and foremost, branching is a great addition to Figma, thank you!
Here is some background on how our Style and Component libraries are setup:
Project: Design System
File 1: Styles (text/color/other token styles)
File 2: Components (primitive components, larger organisms, and some templates)
What I’d like to do is create a branch in File 1 and change our brand color and add some text styles.
I’d then like to “stage” this branch so that I can reference it in File 2 (another file) and test some of the changes downstream in components to see how they might look before merging and publishing File 1 (in case there are things I need to change/add).
I would love some suggestions on how I might accomplish a workflow like this, or if it’s something that might be supported in the future.
Thanks!
Kenneth_Lindbeck-Dahlstrom
May 25, 2021 6:37 AM UTC
+1 for the ability to publish branches. I mentioned it in the slack channel as well.
In addition to the use case mentioned by you @Bryan_Berger, in our case it would be to be able to create v2/vX of components with breaking changes for older files that depend on the old version of the components. The published branch would be used to get files up to speed to the breaking changes.
Sho_Kuwamoto
May 31, 2021 12:16 AM UTC
This is a great request. For now, we are trying to keep it as simple as possible, which means that only single files can be branched, and there isn’t a way to test out dependencies of the sort that you are describing.
We’ll think about this use case some more, but it’s likely that it will need to wait until after the launch of the initial version of branching. Thanks!
Colin_Carter
Jun 4, 2021 10:27 PM UTC
Wow, this is a great idea. +1. Totally get why it might have to wait and, IMO, worth waiting for. We (my team) were just discussing the possibility and benefits of publishing a branch of our library. We currently have a completely separate Beta library for this reason but it’d be great to just have a Beta branch and be able to cherry-pick changes from the Beta branch to merge into Main. Very similar to the way a Staging environment might work in a traditional dev environment.
Ben_Smeets
Jul 1, 2021 2:15 PM UTC
Just to add to the use case, we were looking for something in the past that helped us pick a release date for a new design iteration for the clients/devs to see and use. And not be bothered with all the tinckering in the meantime. Branching was told to be the solution, which it could very well be. But if we can’t update the components definitions (in file A) while doing adjustments in designs (in file B), then we’re still stuck I think. Any in between solutions more than welcome.
Ben_Smeets
Aug 10, 2021 6:53 PM UTC
Any new news on the plans of allowing for a branch using multiple files? Has been a while, not sure when Branching is going to be released as mentioned before you get a chance to look at it (not sure, but it might already be released :)).
Asking only because branching as a concept is currently not useable for us, since the libraries are not attached in the branche.
Bryan_Berger
Aug 12, 2021 6:00 PM UTC
^very much this
delia_tee
Aug 16, 2021 8:25 AM UTC
I agree with Ben. Branching with multiple files would allow us to finally get away from Sketch + Abstract
Alamaki
Mar 4, 2022 8:35 AM UTC
Please add this. Without being able to use a branch of a library, it’s impossible to sanely work on a task that needs changes to a library and a feature file.
DannyEspinoza
Apr 22, 2022 5:57 PM UTC
Please Jeebus, can this be a thing?
DannyEspinoza
Apr 22, 2022 6:00 PM UTC
Any word on this Sho? this would be immensely beneficial to me…
