Moses_Feliz
May 3, 2021 7:45 PM UTC
Option to Hide Frame Labels
The UI can get over crowded with annoying frame/component names hanging off their top edges. I have not found a way to disable/hide these. Please tell me there is a way! 🙂
Will_Chan
Jan 6, 2022 4:27 PM UTC
Thank you Michael
Katie_Bush
Jan 7, 2022 2:57 PM UTC
How can we make this request go viral… this is the bane of my existence and adding SO MUCH NOISE to all things I design…Why is this not a quick toggle to see/not see these labels… It’s borderline triggering to both sides of my brain. @Figma please fix this lightweight (for your ENG team) critical improvement STAT.
Kerry_Johnson
Jan 18, 2022 4:37 AM UTC
Surprised to see such a basic option missing in an otherwise good app.
Kai_Magnus
Feb 9, 2022 10:01 AM UTC
On the other hand, it would be nice if this option could also force labels to show even when frames are within frames. Would make it easier to create component libraries that way.
Emily_Viner
Feb 24, 2022 3:29 PM UTC
so helpful, thanks!
Justin_Pumpr
Mar 31, 2022 11:17 PM UTC
The problem with adding them inside other frames, or groups is you can’t share links to frames within frames. So if I have a mockup for a load of screens and want them all inside a group/frame to a) group them to make moving them easy and b) hide their labels, I can no longer link directly to one of the frames. This is also a very strange problem to have
tm_prof_rs
Apr 6, 2022 2:43 AM UTC
It should be easy to have a simple view option in the top right to toggle frame labels. As a DESIGN tool, this should not insist on making me hack around with groups to hide a software attribute. The layout a designer is working on needs to be viewed pristine. A simple view toggle would do the trick.
Due to frames being so integral to figma structure, it’s not realistic to need group wrappers. This is actually an odd evolution of figma now: you have groups and frames and both are very similar, but not quite. Oddly enough, “unframing” something is done by “ungroup” command.
Dennis10
Apr 8, 2022 3:21 AM UTC
Agreed. Hope will come out soon.
Giulio_Pretis
Apr 11, 2022 11:44 AM UTC
Still nothing an year later?
Lam_Le2
Apr 14, 2022 7:47 AM UTC
My designs were very fine until yesterday! Now some sub-frames decide to revolt and start showing the display names?! Frankly, not all sub-frames show their names. Only a few. And indeed, this is quite annoying.
