Make it possible to move Variable Mode Columns
Johan_Holst
I happily created a variables collection for my existing dark mode and light mode color style palettes that I had in my Design System.
The thing is, my app is primarily designed in dark mode, but I created the light mode variables first and now I’m stuck with having light mode as the default which is very frustrating. My only option seem to be do just delete and redo the ‘light mode mode’ which I’m not that keen on doing.
Screenshot 2023-07-03 at 10.04.45
I wish it was possible to just change the order of my color variable mode columns horizontally using drag and drop, just like how you change order of variant properties vertically.
Robert_Powers1
Often when defining the various breakpoints in variables using modes, it would be great to be able to reorder the columns. Currently, once you set a mode column it is impossible to reorder it and this is not ideal.
👇 Currently these are set and cannot be draggable like rows.
Stephane_Popout
Hi @Johan_Holst,
I built a plugin to save & reuse variables between your Figma files and it could help you to reorder the modes too
Waiting for Figma to build it natively, it might already help you
Here is the small tutorial and the youtube link (if you need subtitles or video below does not work)
Armin_Rouhanian
Hey there Robert. This Idea is great. However, there are other posts about this feature that have more votes, which I will attach at the end of my reply. Please check them out and vote for the one with the most votes. (If you close this post, this might be even better, The chance of dividing votes between multiple posts will get lower.
Armin_Rouhanian
Hey there Johan.
Check this Post:
This post is relevant to what you have offered. But this one has more votes. I suggest reposting your idea in the other thread and closing this one. Hope they add this feature ASAP.
We need this
  • February 4, 2024
greg69
  • 6 replies
  • March 8, 2024
Hi! There’s a new plugin that’s specifically for reordering modes, its called Reorder Variable Modes. You can drag’n drop them in the order you want, specially useful for setting a default mode (first column) after you’ve created several others.
Dennis_N
  • 181 replies
  • July 16, 2024
If you don’t mind threads could be merged @moderators
Jim_Knox
  • Active Member
  • 25 replies
  • October 16, 2024
I work with a system of brands (modes) which I have organised in alphabetical order. I can only create a new mode which adds it to the far right of the table. I need to now add more modes which will need to adhere to this alphabetical order, but there is currently no way (or that is visible) to re-order these modes. Clicking and dragging a column in the table order or being able to re-order them (in the same way we can order properties within a component would be extremely useful and actually necessary).
ksn
  • 1611 replies
  • October 16, 2024
Hiya @Jim_Knox - thanks so much for taking time to provide this! I just submitted your feedback/request over to our engineering team. I will do my best to reach out when I’ve gotten an update.
Dennis_N
  • 181 replies
  • October 23, 2024
Chris20
  • November 17, 2024
Thank you very much for the long-awaited update on Variables – finally! However, some basic table functionality is still missing. I would like to better manage columns in variable data tables:
  • Add a column at a specific location
  • Delete a column
  • Rearrange column order
Chris
Cassie11
  • 5 replies
  • December 21, 2024
Would it be dramatic to say that I am horrified this isn’t currently possible? It seems like incredibly obvious functionality.
Vero5
  • 9 replies
  • March 19, 2025
Checking in and this is still not available! Plugins are not an option at my company because each plugin requires approval from corpsec, which is time consuming and intensive to say the least. Also, requesting the use of a plugin to fix what should absolutely be a built-in feature is...ridiculous.
Mel_Bosch
  • 10 replies
  • March 25, 2025
Hello 👋🏼
is there a way that i can change the position of my variable values.
E.g. i have 20 values and need to add another. The problem is that i always have to scroll to the end of my variable overview.
But i want my “main” values in the first 3 values columns.
Thank you guys!
Mel_Bosch
  • 10 replies
  • March 25, 2025
I can add my topic to this request:
https://forum.figma.com/suggest-a-feature-11/change-variable-value-position-38910
We really need this, AND my company, just like @Vero5, is very restrictive when it comes to plugins.
