"Empty" Auto Layout Frame keeps the size of last hidden child
Show first post
Thomas_Tom-B
  • October 7, 2024
Same here, we shared our struggle as Design System team to Figma France.
We try to align Dev & Design, this is very… annoying.
Happens all the time on every component. So we create “fake boolean property” on the upper container.
It complexifies the property panel / API and requests designers to do stuff manually.
Hope it will come soon 🙂
Autumn_Dawe-Baillie
Just +1 ing this to keep it relevant and boost the request. The way this is working today doesn’t align with how it works in code and is causing confusion for our developers and designers.
Roman67
  • 12 replies
  • October 22, 2024
This bug breaks my expectation of how Auto layout set to “Hug” should behave, and it forces me to implement a workaround when creating flexible components that can toggle layers on and off.
Bethany_Beech1
This is making design of layout components with collapsible sections 100x harder than it should be. Instead of simply hiding a top section and having it collapse/disappear completely, I now have to add complicated workarounds to get the layout to behave as it logically should-- not holding any space or padding if no layer in it is visible. Please fix this.
Yvette_O
  • 6 replies
  • November 18, 2024
Does anyone have a hack/fix for this issue when using a negative gap for the items in the container that won’t collapse? The 0px fix doesn’t work.
Olha4
  • December 6, 2024
+1 ran into the same issue
Klindt_Fabian
In my opinion this feature limitation is a direct contradiction to what Auto Layout is supposed to do? Why would you intentionally add a feature limitation that makes the handover to developers so unneccessarily complicated?
In the Figma Learn article on Auto Layout it says: “Use auto layout to create responsive designs that grow to fill, shrink to fit, and reflow contents” and “Build lists that adapt as items are added, removed, or hidden” but it does not do that due to your feature limitation.
This issue is costing me and my team precious time not only during design, but also when collaborating with developers.
Klindt_Fabian
To everyone else following this topic: our workaround is creating sub-components. Let’s say you are building a card with an optional header, and this header is an Auto Layout containing a couple of different things (like an avatar and a time/date slot, for example, that are shown next to each other). Building the header as a separate sub component allows you to toggle it on/off in the card component. Exposing the sub component in the card component then gives you all the options you need (in this example, hiding either the avatar or the time/date slot independently from each other).
This is not ideal as you, theoretically, can turn on the header boolean and then turn off the two header booleans, which will replicate the bug that is being discussed here - but it does allow you to turn off the entire header.
Jiyeon_Yoo
  • January 15, 2025
+1 please fix
Lea.P
  • 14 replies
  • January 21, 2025
*Push +1
The workaround with subcomponents is not practicable.
This is absolutely not a feature. This is a bug.
And a biiiiiig problem for our design system.
It is not logical at all that auto layout frames keep their dimensions but all child layers are hidden.
Please fix this! thx
Tim_Print1
  • February 5, 2025
Really need a fix for this bug, it is completely illogical and breaks even fairly simple components with boolean contents.
Mads_Emmertsen2
+1 Hoping this gets fixed in the near future
  • February 20, 2025
+1 really need this to be fixed for design systems that our team implement
Andrei Gadoiu
+1. Though I understand the fear others have when dealing with a 0px height layer, this clearly breaks the way auto-layout works.
Alexander Girod
I guess AI is more important now than fixing this issue and provide real quality of life for professional users.
Fraser Hood
  • March 24, 2025
+1 this is starting and will continue to cause issues for designers and developers across our product teams
Kateryna13
  • March 27, 2025
+1 can’t properly use boolean show/hide in complex components
Nick89
  • 7 replies
  • April 16, 2025
+1
2 years later this has still not been fixed? This is starting to become like the "multiple independent strokes" topic. Still nothing while it's very much needed to prevent us from hacking our way through the application...
Onno_Willems
  • 11 replies
  • April 16, 2025
Ha, got here by googling why it behaves like it does and wondering if I was doing something wrong.
In my case: I have 2 items (set to fill width) that have booleans for their visibility in vertical auto layout. The hack with including a 0 height rectangle at the bottom in the auto-layout works, so I'm good. It's just that you loose a lot of time/productivity investigating such bugs, hunting for solutions, etc.
Joseph_Niet
  • 6 replies
  • May 6, 2025
+1 - making a card with booleans to toggle the visibility of items within an auto-layout. When they’re all turned off the height resets as if they were all visibile, instead of collapsing...seems totally counter-intuitive and broken to me?
Rob_Thwaites1
Hi folks, You can solve this with a little hack – I think its been mentioned here in this post, but I didn’t see a screengrab, so here it is:
  1. In Figma, you can set an element to have 0 height (I don’t think this was always the case, but you can do it now).
  2. However, an autolayout container has problems collapsing to 0 height, when it is emptied of elements - it does better when it has a containing element to set its height from, even if that element is 0 pixels high.
  3. Hence the fix is to put in 0-height stroke that will always be at the bottom of your stack. The Container will now reliably collapse to 0px height when all items are hidden inside it.
0 height quick hack
Mads_Emmertsen2
0 height quick hack
I tried this hack but the issue is that the stroke counts as an item so a gap will be created between it and the other elements which will then ruin the size of the frame 😅 so it only works if the frame has 0 gap.
real_witt
  • May 27, 2025
Pavel_Kiselev wrote:
Like to have it the way it is. Hunting zero size frame somewhere buried in layers would be a nightmare
This is a nonissue though, you can still toggle the visibility on in
a) the main component by simply selecting the component (purple dotted bounding box) and toggling the visibility of whatever you hid via the properties panel
b) a component instance by doing the same thing (select component and toggle visibility in the properties panel
Collapsing empty containers in a component instance if all the container children are hidden makes total sense.
Vincent_Schlothauer
Chiming in to say this is a real bummer for design systems.
Say I can display 1, 2 or zero buttons in a banner. When I toggle off both buttons I expect the autolayout containing them to collapse, since it is, for all intents and purposes, empty. With the current behaviour I have to add another toggle for the button container, which makes the properties panel confusing to designers.
We used to use subcomponents to prevent some of these issues, but since running into major performance issues with our prototypes last year Figma recommended we use fewer nested components. So this is a lose-lose situation unfortunately.
Julia57
  • Active Member
  • 46 replies
  • July 3, 2025
It is now 3 years later and still not fixed. It’s insane. there is no good workaround because even if I add a 0px frame, it will still cause extra space to be taken up due to the parent’s ‘gap’ setting.
