Antoine
May 19, 2022 12:11 PM UTC
"Empty" Auto Layout Frame keeps the size of last hidden child
Hi, I’m not sure if this is new since the May update, but I wonder why “empty” (all elements hidden) Auto Layout Frames keep the size of the last hidden child (and I do not mean last in the list, but the last element to have been toggled out of view by the user), making them not-0px high even with nothing in them.
See here a file with a Frame with three hidden rectangle: the Frame keeps the size of the last child rectangle to have been hidden. When adding a 0-px Frame to the AL frame, and toggling this 0-px Frame off last, the container goes 0-px.
In my opinion, empty AL Frames should have a height of 0. What do you think?
Pinned Reply By djv
Hey All, thanks again for your continued feedback, and I finally have an update!
As mentioned previously, this is behavior is currently a known feature limitation in Figma. We do not allow Auto layout frames to collapse to 0 when the child layers are hidden, so it is expected that the frame will remain sized as if they were shown.
The team has confirmed that they now have the bandwidth to get this working as expected. In the meantime, they have a temporary solution: Add a visible zero-sized frame. Since the container is then not empty, it will hug to the visible child, which is zero-sized.
While I know this may not be the solution you want, please know that we’re getting closer. I’ll be sure to update you all again once we have a more firm timeline on the fix.
XavierV
Aug 25, 2022 9:58 AM UTC
Hello, so is this a bug or not ? If not is there a new “idea” created to promote this feature somewhere ? It’s very annoying, the only way for me is to create a property to collapsed the empty frame and it’s very dirty… 😦
Edwin_Bradford
Oct 6, 2022 10:49 AM UTC
My understanding is Figma is meant to support design for frontend languages. Since collapsing to zero is exactly how frontend languages work (css) then shouldn’t that be the expected behaviour. I don’t have a lot of sympathy with it being “annoying” or “tedious”.
JonnyA
Oct 7, 2022 7:56 PM UTC
This is indeed a bug we discovered recently. Turning off all the child elements inside a group set to “Hug” should collapse the size of that group to 0px but it doesn’t. @figma please fix this so we can still use our magic properties!
Jen_Heiner
Dec 6, 2022 5:21 PM UTC
Also running into this issue. Will need to use variants instead of booleans 😦
hosley
Mar 13, 2023 8:32 PM UTC
There’s probably a good reason for not fixing this, but in the meantime it’s incredibly frustrating and means that I end up needing to hack in various ways (add another boolean to the container?) instead of just having this behave logically.
Madness 😦
Stan5
Mar 27, 2023 11:54 AM UTC
This has to be a bug, it breaks slotting which is a super important design system technique
Mira_Geborska1
Apr 12, 2023 11:29 AM UTC
Struggling with the same. I would expect the group set to HUG, to have 0px if all it’s children are hidden. It makes it so painful to create components with boolean properties right now.
Pedro_Vinagre
May 4, 2023 9:49 AM UTC
Any updates on this?
Andrea_Crouch1
May 17, 2023 9:30 PM UTC
+1 - I would expect the parent contain with auto-layout applied to have a width or height of 0 if all children are hidden.
Averyy
May 24, 2023 2:03 PM UTC
Yep this is making booleans frustrating.
CSS collapses to 0, so autolayout should as well. The 0px shape/frame workaround doesn’t work as it requires a 1px minimum height.
