Antoine
May 19, 2022 12:11 PM UTC
"Empty" Auto Layout Frame keeps the size of last hidden child
Hi, I’m not sure if this is new since the May update, but I wonder why “empty” (all elements hidden) Auto Layout Frames keep the size of the last hidden child (and I do not mean last in the list, but the last element to have been toggled out of view by the user), making them not-0px high even with nothing in them.
See here a file with a Frame with three hidden rectangle: the Frame keeps the size of the last child rectangle to have been hidden. When adding a 0-px Frame to the AL frame, and toggling this 0-px Frame off last, the container goes 0-px.
In my opinion, empty AL Frames should have a height of 0. What do you think?
Pinned Reply By djv
Hey All, thanks again for your continued feedback, and I finally have an update!
As mentioned previously, this is behavior is currently a known feature limitation in Figma. We do not allow Auto layout frames to collapse to 0 when the child layers are hidden, so it is expected that the frame will remain sized as if they were shown.
The team has confirmed that they now have the bandwidth to get this working as expected. In the meantime, they have a temporary solution: Add a visible zero-sized frame. Since the container is then not empty, it will hug to the visible child, which is zero-sized.
While I know this may not be the solution you want, please know that we’re getting closer. I’ll be sure to update you all again once we have a more firm timeline on the fix.
Klesus
May 19, 2022 12:58 PM UTC
I don’t know Figma’s reasoning, but to me it makes sense not to collapse empty autolayout frames because if they become size 0 then it would be tedious to put things inside them.
Antoine
AntoineAuthor
May 19, 2022 2:40 PM UTC
I agree, it makes sense, although the logic is hard to understand. The actual issue I have is related but not the same exactly: when this “empty” Frame is made into a component, it will keep its maximum size even with no displayed content.
It’s an issue when implementing component toggle properties in a component. Say your component has three possible zones: A, B and C, but B and C are wrapped in a Frame in the overall structure. You can’t create toggle properties for B and C without having their wrapper keep its maximum size (and thus the overall component not hugging only A, for instance). The only way to go is to add a fourth toggle property for the wrapper, not ideal.
Klesus
May 20, 2022 5:19 PM UTC
I think I understand.
A possible workaround might be to put a 0 size frame between B and C. Or at least somewhere in the same frame as B and C, but assuming there’s paddings involved, putting it in-between IMO seems the easiest, but might not be viable if you have more than 2 children. Either way, after that you might have to make adjustments to make it look nice but it could work.
The problem is because a component with autolayout resets it’s size when all it’s children are hidden, but if you put a 0 size frame inside, which isn’t visible either way because it’s so small, it still counts because it’s not hidden, and the component will hug it.
Matt28
May 24, 2022 4:31 PM UTC
I think am having the same issue:
I have a component with a horizontal Auto-Layout frame with 2 elements that have boolean properties. If I turn off both elements what I want to happen is for the container to collapse.
It makes sense why it doesn’t, technically, but when we were just using variants I could manually hide the container itself when I had a variant with both internal elements hidden. Now if I’m just using the boolean properties I can’t do that.
Rhys1
May 31, 2022 1:05 AM UTC
Yeah im getting this too, the auto layout frames should completely collapse, it makes boolean visibility probs useless in some cases where it should be used
Pavel_Kiselev
Power Member
Jun 1, 2022 12:34 PM UTC
Like to have it the way it is. Hunting zero size frame somewhere buried in layers would be a nightmare
Adam_Diestelkamp
Jun 1, 2022 2:33 PM UTC
Having this issue to when building a component. Placing a 0px shape does work but not ideal, would much rather have the whole autolayout object collapse to 0.
It also keeps it’s padding even when using the 0px hack which for me causes unnecessary padding/spacing. If the whole thing collapsed then the spacing would go away between the items and not have the extra padding.
Dennis_N
Power Member
Jun 7, 2022 12:01 PM UTC
I absolutely agree that the frame should collapse in that case.
Dan_Szymanowski
Jun 24, 2022 12:27 AM UTC
I understand not wanting the container to collapse. However, logically it should - assuming we expect the design to behave as it would in code.
Additionally, it makes it tremendously difficult to effectively utilize auto-layout with many of the new component prop features - notably boolean show/hide.
Doubleo
Jun 30, 2022 1:33 PM UTC
I’m also having this issue, building components with boolean visibility. If there are two components in a “wrapper” auto layout frame, even if both children are hidden, the layout would not collapse. One workaround is to use another boolean just for the wrapper, but it’s just one more property to manage. The 0 height frame approach doesn’t work either, because the padding still doesn’t collapse as @Adam_Diestelkamp said.
This makes the new boolean property quite unusable in complex components.
