Edit nested instance properties for multiple selected child components
  • October 10, 2022
  • 7 replies
  • 876 views
Leo_Vogel
I would like to be able to selected multiple child components which are all associated with the same parent component and edit their shared nested instance properties across all selected child components.
  • January 8, 2023
Isaac_VanDyne
Why can you not adjust the nested instance props of multiple instances of the same component at once? This limitation forces you select the nested instance in each component to make changes. Very frustrating bc it seems like this should be extremely simple change – just surface nested instance props when multiple components are selected. @figma pls
  • 4766 replies
  • June 17, 2024
Hey All, thanks for the feedback!
We’ll pass this onto the team for future consideration. Don’t forget to also vote up top! ☝️
Our team uses votes form the community to prioritize and gauge overall interest from the community.
Chris_Roy1
I thought this used to work but maybe I imagined it. Not only do I need to go one by one to change nested props I also need to expand the nested props each time which adds a lot of overhead vs being able to select many all together and updating in bulk.
I’m surprised there are not more votes on this.
Dominic
  • 40 replies
  • February 5, 2025
+1 , much needed.
Faezeh_Mashmool
Hi Figma Team,
I frequently work with nested components, and one major limitation I’ve encountered is the inability to edit nested component properties when selecting multiple components at once. Even when the nested components share the same properties, I still have to edit each instance individually, which can be time-consuming and disrupts the workflow.
It would be incredibly helpful if we could modify shared nested properties across multiple selected components at the same time—just like we can with top-level variants and properties. This would significantly improve efficiency, especially when working with large design systems.
I’d love to see this feature in a future update! Hoping the team considers it, and I’m sure many other designers would find it useful too.
Barbora_Vlaskova
I agree with all above, I created design system, where I need to use nested properties in instances and it seems I will have to create variants of each possible instance to do work smoothly.
