Hugo_Jerks
Jul 16, 2024 6:28 AM UTC
Bring back independent object W + H within auto layout
When using auto layout the new UI update has moved the current width and height of a selected object to behind a hover state. Width and height only accessible via the hover state of the auto layout types (fixed, hug, fill).
I often use the actual W and H of elements as a sense check for ensuring the design works within our design system.
Please bring back the independent readings.
Jul 18, 2024 7:33 AM UTC
Thanks for sharing your idea! I’ll share your feedback internally.
Meanwhile, I know it’s not an ideal tip for you, but let me share one as well. If you expand the right panel a bit, the W and H of the object will appear in parentheses next to Hug/Fill.
I hope it helps.
Toku
Hugo_Jerks
Jul 24, 2024 12:45 AM UTC
Thanks @y_toku, that’s definitely a helpful tip for a quick fix!
