Jenia
February 2, 2024
Add Dev Mode To Professional Subscription separately from design seat
  • February 2, 2024
  • 75 replies
  • 3071 views
I am outraged. How do you imagine I allow all my devs to be full-seats and give them the ability to edit designs? How about design ownership? In a day all devs lost their inspect tool, and the only way to get it back is to move to Org Plan or give them a full seat risking to get full chaos in design ownership. Any suggestions on how your teams ar planning to overcome this?
Nikita_Furmanov
February 2, 2024
Same question
Rogie_King
Designer Advocate
February 2, 2024
@Jenia Your frustration is felt, and heard. I’m noticing that this rollout has been especially confusing. Before you make any changes, Tom, on our advocacy team made this video to help explain how you get at code and properties that you’d normally see in the inspect panel, which is now called “Properties” —
Video on Twitter:
twitter.com
I hope this clears up some of the confusion. We’re bringing all of this feedback to the team and hoping we can make some actionable changes to make this clearer. Please reach out and let me know if you have any other questions.
David_Leggett
February 2, 2024
@Rogie_King This is a massive downgrade to functionality we had BEFORE dev mode was ever introduced.
When Figma announced Dev mode, the spirit of the conversation was that we would continue to have these features that were always available once Dev mode came out of Beta. This is a huge rug pull.
Rogie_King
Designer Advocate
February 2, 2024
David, totally understood this nature of the “downgraded” experience — in your opinion, what are the changes to the experience that feel most negatively impactful?
David_Leggett
February 2, 2024
At least going back to 2020, we had the ability to quickly reference properties directly in Figma. With minimal effort we could visualize, copy, and paste exactly the things we needed.
The recommended approach now is to copy from a context menu that copies code for all child objects of a selection, paste it somewhere else, and then manually find the things we need from a huge paste.
This is way more time intensive than it used to be. I just tried it on a really simple selection and it copied over 700 lines to my clipboard, but I don’t get to see what’s being copied until I paste it somewhere else.
We used to have such an easy way to grab props, and content by toggling between a “<>” code and content view right in inspect.
Please bring this back.
CamilaB
February 2, 2024
Thanks for sharing this. I was feeling a little gaslighted when people said only the code part was changed because I was sure there were more details than the code part comparing the old “Inspect” to the new “Properties” tab. For non-designers it’s much easier to understand the frame sizing with the image instead of description as well.
dennsi
February 5, 2024
Hey all!
tl;dr: Professional Plan does not offer Dev-only seats. Currently, Devs automatically have Design edit rights when they got upgraded for Dev-Mode. This clearly needs some rework! Please remove automatic edit rights from Dev-Mode seats.
Currently we are running on a Professional plan with a small team (2 designers 2 devs).
Today, as the team owner I upgraded our Devs so they can continue using Dev-Mode.
However the upgrade just allows me to set their “Design seat” roles to “Full”.
Since they do not need (and want) edit rights and just want to use Dev-Mode I tried setting them to “Viewer-restricted”.
I assumed this would remove their edit rights and keep the access for Dev-Mode since we have enough seats in our plan. Unfortunately, this does not work. It completely removes access for Dev-Mode.
Figma, please look into this and improve the team management experience and separate the edit rights from viewer-based rights such as viewing files and using Dev-Mode.
The easiest solution would be to simply add Developer seats like in higher tier plans.
Alternatively add a new third role that combines “Viewer-restricted” with enabled Dev-Mode. Design/Edit rights should be opt-in for Developers and manageable since they do not need or want them anyway.
Joseph_Barbier
February 5, 2024
Howdy @Tom_Lowry @Rogie_King ! Curious if there’s any further response on this. Thanks! 🙂
February 5, 2024
Agree, very annoying and uneccerseraly expensive for small teams who dont need large subscription plans.
Rogie_King
Designer Advocate
February 5, 2024
Hey Joseph, no word yet, just busy taking all of your feedback and bringing it to the team. Thanks for your patience!
