Jannis1
Jul 4, 2023 10:37 AM UTC
Variables do not update in design
I am working with a colleague and some local variables simply do not update in the design when she is entering new values in the local variables window. Some do, some don’t.
I on the other hand are able to update all variables with no issue.
Both are using latest Figma Version via App. Only difference she is working on Windows, I am on Mac.
Celine_Solution
Jul 17, 2023 8:27 AM UTC
Hi @Weston_Ballard ,
For visibility, I can see in the back end that the issue was related due to a missing font for your case. If you see a yellow A? icon:
Manage missing fonts, Manage conflicting fonts and Access local fonts on your computer might all be helpful in clearing those missing font warnings so that changes they make to the variables are reflected in the file’s text.
Still, I recommend you to reach out to the support team to have a deeper look at your file, as it may be another issue. Please contact the team by filling this form: here
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com as an Editor so they can take a closer look. Thank you!
jessie1
Sep 21, 2023 1:42 PM UTC
I have this issue as well. I updated some primitives and even though the associated tokens have been updated in the variable menu, and even show correctly in the colour menu, the items where those tokens were applied to do not update, even in the same file. I restarted, closed and opened tabs, etc. The only way to “fix” this is by individually selecting the affected items, assigning a new colour variable, and then back to the original one…? Pls fix.
Osung_Jung
Sep 26, 2023 11:03 AM UTC
Hey Figma. Please get this resolved.
Though you make changes to variables colors in main library file.
A separate file that use that library will not update with the variant colors. Doesn’t work if you update the changes.
Only works if you bring in a new component in. Or reset the whole component. Which is ton of work.
Please fix soon.
RizePoint_Product
Sep 26, 2023 9:21 PM UTC
This speaks to a key issue with the way tokens are implemented: there’s a difference between “local” tokens and library/published tokens even within the file the library tokens are from.
The (EXTREMELY ANNOYING) fix for this is to change all your tokens to the library versions of the tokens once you publish the library, and make sure that going forward you’re diligent about publishing the library after you make changes to the local variables, then applying the changes you made to the global variables via the component update menu. That’s the only way to keep the two consistent.
I think this process makes no sense and hope they change it.
Craig12
Sep 28, 2023 8:17 AM UTC
Same issue here. Local tokens simply not updating when flipping a page to dark mode. Library tokens working fine.
It doesn’t make sense to create a library token just for this one instance. This is a definite bug and notably impacts the usability of tokens as a whole if I can’t trust they are working properly.
Nov 17, 2023 1:22 AM UTC
This may be an annoying workaround, but reloading the tab helps me refresh the variables.
Pauline_Jouitteau
Jan 29, 2024 1:50 PM UTC
Does this bug was fixed? I have the same problem, When I am creating a new component or updating an existing one with variable, the variable disapear if I am using the component in another tab/project.
Very annoying 😕 Is there a way to fix that? I tried to refresh tab but it does not work.
gemmy
Feb 7, 2024 7:22 AM UTC
Any update on this? Seems the problem persists. It is very time consuming to have to update the variables in the design manually.
Carolina
Mar 27, 2024 2:32 PM UTC
Hi! I’m experiencing the same issue. Tokens updates in my library are not reflected in the design file. Is there any advice on this?
Apr 4, 2024 1:09 PM UTC
Same issue here - I have set up Light and Dark mode color variables in a “Master Design System” file. Upon changing a few color variables for Dark mode, they aren’t water-falling into files which use this Design System library.
I’m having to go into the color setting of each component in my working file to manually select the new variable, which does show accurately. Again, just having todo it manually.
Pugovkin_Vasiliy
May 14, 2024 7:46 AM UTC
I have a similar issue and it reproduces 100% of times. Any color variable I have in a library file will not update in local files if I change it in the library and publish it. I can see the color changing in the color selection menu, but the actual object will stay the color it was when assigned originally. This makes using variables as library tokens useless. 😿
