Prototype resetting Scroll Position
lizaplastun
The problem is still relevant. Can I find out if there will be a fix?
Continuing the discussion from Prototype resetting Scroll Position even though those settings have not been selected:
Best answer by tank666
Do I understand correctly that the bug occurs when collapsing/expanding chapters? If yes, then this is due to a bug in the smart animation of auto layout frames. There are two solutions here:
  1. Instead of “Smart animate”, use “Instant”.
  2. Wrap your auto layout in a frame of a fixed height (set the height equal to the height of the device), and also change the overflow scrolling behavior (from “No scrolling” to “Vertical”) of this frame.
tank666
  • 4873 replies
  • April 1, 2024
Have you followed these Help Center articles?
Figma Learn - Help Center
lizaplastun
Yes, I read these articles. I have a problem with animation in components. When animating simple frames everything is fine. And when using an animated component, everything breaks. I can’t find the reason.
tank666
  • 4873 replies
  • April 1, 2024
Could you share a link to the example file?
lizaplastun
Figma – 1 Apr 24
Here’s an example
tank666
  • 4873 replies
  • April 1, 2024
lizaplastun
The second option worked! Thank you very much!
Louistdesign
I just watched this video
And you can fix it way more easily by renaming your frame with the same exact name and differentiating them using a “/...” it fixed the issue for me and was a real life saver
