Issues with nested component scaling
Hey Figma team,
I wanted to report a problem that’s been bugging our team for the past few months.
We have an Icon Library in our design system, as well as a separate glyph library. These icons are used in different sizes across the product (16px, 24px, etc.). The master components of each icon and glyph contain elements which are all set to ‘scale’.
However, within our larger components, whenever we want to swap an instance of an icon with a different one from our library, the scaling (of dimensions, stroke width, and border radius) is not properly applied, resulting in a broken view.
One example is:
  • We have a nested icon component scaled to 16x16px;
  • We replace the instance with another icon from either library (original component of which is 24x24 but all elements set to scale) and expect it to scale properly to the 16x16 dimensions. However, the swapped icon appears broken in terms of the scale of elements inside, stroke width and border radius;
  • We have to resort to a workaround like: 1) Detaching from the master components, 2) Resetting the icon to its original size, 3) Scaling it again to the desired size. Which works for now but it’s frustrating we can no longer make use of the flexibility of the overall component’s properties.
It would be great if these scaling issues are fixed in future updates.
Appreciate your time looking into this!
  • 3539 replies
  • April 29, 2025
Hey Alex,
Thanks for sharing all the details — I understand how tricky this scaling behavior can be, especially with nested components!
I saw that you've already contacted our support team. (Your support ticket is  #1314238.) The agent is currently waiting for your response to continue the investigation. (For your information, once you respond, your support ticket will automatically re-open.)
If you can, please reply to the support ticket with a brief video recording showing the issue. Make sure the full Figma window is visible, including properties and layers panels with relevant layers expanded. This will help the team to reproduce and better understand what’s happening. Thanks again!
Julien Blanchet
Hello!
I have the same issue, do you finally find a solution?
Thx !
Julien Blanchet
Hey, problem seems to be solved with the latest update :)
Robin B.
  • June 3, 2025
@Julien Blanchet Nah the problem still exists. At least for me, the components in other states are still displayed in the original size when they are changed via the nested instances…
  • 3539 replies
  • June 3, 2025
Hey ​@Robin B. , sorry to hear you are still having issue on your end. For visibility here, we are still waiting for ​@Alex A ‘s response for further investigation.
I’d recommend submitting a bug report directly so our support team can take a closer look and investigate the root cause on your end: Submit here
Please use your Figma email account,  and in the form, share a direct link to the file, and invite support-share@figma.com with "can edit" permission to your file so the team can look into this further. Note that users with @figma.com emails on your team do not count towards your billing.
Thank you!
Julien Blanchet
My bad, ​@Robin B. is right, the issue still exists… ​@Celine_ I will submit this bug report too
