Changing instance via variable resets text (and other properties) when inside component
Tascha
So, in principle, if an instance is inside of another component, changing the variant causes the text to reset back to the text of the master component.
This also happens with other properties of the instance, e.g. if you set some booleans up they will be reset to how they were set in the master component once the variant is changed via variable.
Here’s a screenshot of what I mean:
and here’s the link to the file to mess around with.
(So, this issue might be similar (or even basically the same) as discussed here: Change to on instance not keeping text change but frankly I haven’t had the patience to look into OPs setup 😅 I tried to break the issue down to the most bare-bones that I could in the file I provided (also to see if the issue has anything to do with my components or just is a bug)
If anyone has found a workaround do let me know 🙏 (and yes, I do need the instance within another instance; it’s a button inside a form layout that I want to reuse (and many other such cases).
Marino_Panariello1
Same problem here, someone know a workaround? thank you
Aris_Aurellano
Also running into this issue. I feel like we wouldn’t have to do this if there was a click away / on blur feature for prototypes.
Tanna_Teixeira
The exact same issue is happening for me. I have scoured forums, and the bugs list to see if I am doing anything wrong. I have also attempted to contact Figma multiple times which has fallen on deaf ears.
I am also using nested component instances and when I change the String and Boolean variables in that instance, the changes not only don’t appear in my prototype. They also eventually disappear from my file all together. I have tried the suggestion to check the “Reset component state” box which hasn’t helped at all.
If anyone has found a work around to this issue please let me know! I’m getting desperate as I have to present my prototype soon and I can’t keep having to go back and redo all of my work!
Thanks so much!
Nisha_Huston
I had the same issue, worked around weeks, and for me, the problem was solved by simply NOT HAVING the text property in the component, and if I needed to edit the text in the instance simply command-click on the text layer to edit it, that way it didn’t reset and all worked just fine
Johannes_Eckert
We have the same issue in our design system and it’s causing a lot of annoying frustration.
We narrowed this issue down when a string property is changed with a variable (like iOS and Android). Which I think what OP is seeing here, too. The component resets to it’s defaults when the property is switched with a variable mode, see here:
Screenshot 2024-11-14 at 15.57.01
But when we switch the mode manually, we see everything working as expected
Screenshot 2024-11-14 at 15.57.34
We have had this issue for a couple of months now. There does not seem to be a workaround.
andraspii
  • 6 replies
  • December 15, 2024
Same here. If I change the variant manually it keeps the texts, but if it changes based on the variable, all texts reset to the value of the default component.
Dear Figma! Please fix this issue ASAP.
Dominic_Cartlidge
I’ve been having this issue for months and am honestly astounded this bug exists, in what appears to be a pretty core functionality. This really needs to be fixed.
Saraha
  • 4 replies
  • January 28, 2025
This is what drives me absolutely insane! It looks like it’s working in the file but once you start the prototype, it just isn’t 🤯🥲
My only workaround so far has been to either detach the instance from the parent or to get rid of the text property, both of which are quite inconvenient.
martiankid
  • 9 replies
  • February 16, 2025
Dear Figma team, please fix this issue, as this is a core functionality for building/utilizing a flexible componens in DS. This bug renders the whole concept of assigning variable to the component variant useless, as you’d expect the overrides to stay during the change  🙏🏻🙏🏻🙏🏻
  • 5 replies
  • February 24, 2025
Please please please fix this. Absolute killer for making interactive prototypes like booking flows.
Kyle_Johnson
  • 5 replies
  • March 13, 2025
Bumping this as I am having the same issue and its very frustrating.
Eugene Ruddy
+1, please tackle this Figma!
Olena Skaist
I completely agree! This is a crucial functionality for maintaining flexibility in a design system. The current behavior makes assigning variables to component variants ineffective, as the overrides should persist when changes occur. Hope this gets fixed soon!
Halyna Hlynska
I totally support this! It’s an important part of building flexible components in DS, and having it work as expected would be a huge improvement. Hope to see this fixed soon! 🙌
Rick_van_Grinsven
Also adding my +1 as we can do everything the right way, but then once you add a variable to change variants: Poooooof, it’s ‘broken’. The recordings of Johannes speak volumes.
Ari Scott
  • March 20, 2025
I just built a design system using this feature, allowing quick switching between mobile and desktop variants when switching modes. However, when components reset during mode changes, it renders property-to-variable connections practically useless.
Jarek_Marciniak1
+1 here
The text component is dead feature at this point. We need to be able to change the properties od the text component without resetting the text content everywhere.
ItsDrivingMeCrazy
Seriously can we please fix this??!! This is making my prototype pretty much unuseable and prohibit me from showing designs to users. This is so frustrating!!
Alex_Hazel
  • 5 replies
  • April 28, 2025
Bumping.. +1 Having this issue as well!
Leo_Vogel2
  • 8 replies
  • June 3, 2025
+1 - Also, having this issue.
  • 4825 replies
  • June 4, 2025
Hey All, thanks for flagging this issue and apologies for the lack of acknowledgement here!
Our engineering team confirmed that this is a longstanding bug that they unfortunately won't be able to fix.
This issue typically happens when you've gotten into a bad data state by:
  1. Unbinding a style on an instance (creating an text style ID override)
  2. The style already had variables or you bound variables to the text data (creating VCM overrides)
  3. Rebinding the original style (creating another text style ID)
The only workaround would be resetting your instance overrides and applying the overrides again. Even though the style is the same, this is happening because it’s not properly inheriting from the component because of the override, so you must reset:
  1. Reset instance
  2. Add text content overrides again
  3. Publish
For additional help with this, please feel free to reach out to our technical quality team here: https://help.figma.com/hc/en-us/requests/new
Frank_K
  • 12 replies
  • June 13, 2025
  1. Reset instance
  3. Publish
I can see how this might be a work around but it breaks the inheritance of the design so here we are back to having to redesign each item and having no way to inherit master changes. We still want the master interaction changes to take place  but be able to override some in an instance - this seems a relatively basic need for users who are sold the idea of a design system and component extendability by Figma. I.e. I have notices that text I place in a certain state, reverts back to the master component placeholder text when interacted with - an ongoing bug for a system that is meant to allow this extensibility.
