Apply changes button disabled when updating from main
Ethan_Wang
Hi there,
I’m trying to update from main to one of my branches. There are 3 conflicts. After I resolved them and went to the next page where it shows all the other non-conflicting changes, the Apply changes button is disabled for me. I can’t click on any of the changes/layers in the right preview pane either. Am I doing anything wrong here? Would appreciate any help or pointers!
Thanks!
Ethan
Ethan_Wang
  • July 8, 2021
Also is there a way to skip other non-conflicting changes from main? I pulled in those non-conflicting changes but somehow it thinks those changes were made in the branch and showed up as branch changes in the review and merge dialog.
Jong
  • August 3, 2021
Same for me here. Help!
Ilia_Lebedev
Same for me. Stuck with an update
Alex_Xu
  • Figmate
  • 14 replies
  • August 5, 2021
Hi everyone,
Sorry for the late response! Are you editors on the branch? If not, then you won’t be able to apply updates, even if they are available.
Otherwise, please DM me your file URLs and share them to support-share@figma.com.
Thanks for your patience!
Alex
Alex_Xu
  • Figmate
  • 14 replies
  • August 5, 2021
Also, updating from main does require pulling in non-conflicting changes as well. But, it isn’t expected to see them “double-counted” when you merge them back into main. Let me know if the problem persists! Otherwise, we can investigate your file via DM.
Matteo_Gratton
Is this still a problem?
I am facing the same issue today:
  1. In a branch as editor
  2. Update in Main
  3. Check the updates → no conflicts
  4. Greyed out button
Can anyone help me, please? (I cannot share any link)
Matteo_Gratton
FYI: it seems it is a problem with the App: I tried from the Browser and it worked nicely and smoothly!
I had the same issue, cannot apply changes in app, but no issues in browser. Seems like a bug.
Philipp_Distler
Had the same issue. Reloading the tab in the app solved it for me.
Right click the tab → Reload Tab
Patrick-Plaggenborg
Thank you!
Just had the same issue with a greyed out ‘Apply updates’ button and can confirm that it worked properly after reloading the tab. The button showed up as blue again.
Dennis_N
  • 193 replies
  • February 7, 2025
Yep, this still happens but reloading helps. Thanks for sharing that solution ♥
Tyler_Wetzel
This is still an issue.
