Josh
Former Community Manager
Jun 22, 2023 3:24 AM UTC
VS Code extension — tips if you're having trouble getting set up
Hi there,
The Dev Mode team are looking into the problems some people are having while trying to get started with the VS Code extension, and hope to have updates out soon, but for now have asked us to share the following tips:
  1. The extension is not currently compatible with VS Code Insiders though we’re hoping to have support for this soon. For now we suggest use the regular VS Code version if you’d like to use Figma for VS Code: Download Visual Studio Code - Mac, Linux, Windows
  2. If you are are stuck in a loop of VS Code asking you to “Accept terms and conditions” please log into VS Code before connecting in Figma.
You can log in to the VS Code extension by:
  1. Clicking the Figma icon in the sidebar of VS Code
  2. Clicking “Log In” and following the instructions
  3. You can then click “Open in VS Code” in Figma however, you may need to accept our Terms of Use to allow VSCode to connect.
  4. In order to accept the Terms of Service, you’ll need to click “Next” in the Dev Mode modal.
Once we have any updated information the team will post it here and if you have any follow up questions about these suggestions, or continue to have trouble getting started with the extension we’d appreciate if you can use reach out to the Product Support team directly via this form: https://help.figma.com/hc/en-us/requests/new
Thanks!
    Jul 1, 2023 8:12 AM UTC
    I had the same issue even though I was already logged in to my account and I could not log back in, so I went back to version 0.1.2 of the extension where I had the option to authenticate ( log in ), logged back in to my account and then updated the extension to the latest version, it works now
    Jul 3, 2023 7:42 AM UTC
    These are the error message I got when clicking the Login/ Restart login flow button
    Jul 3, 2023 4:45 PM UTC
    VS Code Insiders is the latest VS Code version. If this Figma extension is not compatible with it, wouldn’t it means that it won’t be compatible with future versions of VS Code ?
    Gilead_Odo
    Jul 12, 2023 4:00 PM UTC
    I can’t get past that loading state. I can’t access my projects.
    Jul 13, 2023 8:31 AM UTC
    Screenshot 2023-07-13 at 10.03.35
    Same here
    Gosia4
    Jul 17, 2023 8:06 AM UTC
    I alsp have the same issue 😕
    Gilead_Odo
    Jul 19, 2023 11:49 AM UTC
    To address the issue at hand, I have discovered a workaround that involves performing the following steps:
    1. Close VSCode completely.
    2. Reopen VSCode.
    3. Open the Figma extension within VSCode.
    4. A login prompt will appear, prompting me to log in.
    5. After successfully logging in, I will be able to view my projects within the Figma extension.
    By following these steps, I have been able to overcome the problem temporarily.
    Jul 19, 2023 6:54 PM UTC
    Has there been a resolution to the issue with the login flow doing nothing? I’d love to use this plugin.
    Jul 25, 2023 12:34 PM UTC
    try logging in again
    1. While in VS Code, Press Shift+Command+P to Show and Run Commands.
    2. Select Figma: Log out from the list of options in the search bar.
    Aug 6, 2023 9:02 PM UTC
    This seems to be an issue with the Windows Credential Manager
    Delete a few VSCode entries from there, and Figma login should work!
