Variables from an external library added to the file are not showing up when trying to assign them to a value of a local variable
Stanislav_Carla
Some of my colleagues have the same issue. They are editors in a file. The libraries are enabled, everything seems to be set properly. Did you manage to find a solution?
Best answer by djv
Hey All, sorry to hear you were having trouble with your libraries and apologies for the delayed reply!
This sounds related to a bug that we had and launched a fixed for a few days ago. This should have fixed itself if you were able to relaunch or refresh your tabs.
Please let us know if you’re still having issues.
Stanislav_Carla
Correction: They are not editors, they have view rights in a file
Jeremy_Knudsen
Hello Figma Community! 👋
Maybe you can help… I have created an external library of color variables that I would like to use in this file. I have added the external library that contains just color variables. Yesterday, I was able to assign a variable from this external library to variables in my local file. Today, the flyout shows no variables and just a message “No colors available”.
Has anyone experience this issue before? It was working yesterday. Nothing has changed overnight, and now the variables do not show up in the local file. Any help would be greatly appreciated!
Thanks!
Jeremy
Billy_Harris
Also having this issue!
  • 4825 replies
  • March 18, 2024
Stanislav_Carla
Hi! It seems that the issue persists. What the developers need to see are the variable names so they can implement the designs, but they still only see the HEX codes.
Billy_Harris
Hi yeah, issue is still persisting - tried reloading tabs and restarting the app also in the browser. Having to copy hex codes manually 😦
  • 4825 replies
  • March 20, 2024
Hey @Stanislav_Carla and @Billy_Harris, sorry to hear you’re still having issues!
Can you please confirm what OS you’re using? Is this happening when using Figma in the browser and the desktop app?
We’ll pass this onto the team to investigate.
Stanislav_Carla
Sure, we’re using Windows 10 and it’s happening when using the desktop app.
Thank you for checking!
  • 4825 replies
  • March 21, 2024
Thanks @Stanislav_Carla!
I’ll pass this onto our team to investigate further.
Jeremy_Knudsen
This is fixed for me now.
  • 4825 replies
  • March 21, 2024
Glad to hear that, @Jeremy_Knudsen!
Please let us know if you run into any further issues.
I’ve the same issue, suddenly variables from the connected library are not showing in design files. Tried to clear the cache, relaunch, even link it to a new test file. Any idea?
  • 4825 replies
  • April 30, 2024
Hey @Moataz_Galal_Eldin, sorry to hear this is happening. This is likely a new issue, since a fix for this topic has already been pushed.
Please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look.
I have the same issue
  • 4825 replies
  • May 29, 2024
Hey @hana.klust, we pushed a fix for the original issue on March 18th.
Since this is likely a new issue, please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share edit access with support-share@figma.com, so the team can take a closer look.
mbeyer
  • May 30, 2024
Don’t know, if it is the exact same issue, but I ran into a similar issue yesterday:
I have a library with all my text variables, size-xs to size-xxl, line-height-xs to -xxl etc. you get the idea.
I was working on a file, where I had included this library (amongst others), when suddenly all the sizes disappeared when I tried to apply them to a new(!) text element.
The elements I had applied them before still had their variables, but they didn’t show up for new elements. Funny enough, not all text variables vanished, only weight and size. line-height, kerning etc. all were fine.
I managed to get them to work again. Seems like the filtering (only show this var in text context etc.) doesn’t work cross files anymore. Once I manually set them all to appear in all input fields and republished/updated, it worked again.
Ekaterina20
I had the same issue today, when it would be fixed?
Sara_Jonason
Me and the developers I’m working with have the same issue it seems. I’ve assigned a style to elements, but they as viewers can only see the HEX code. They have access to the color library and can see color styles of the same library for previous elements but not for new.
Any fix for this?
Frank_De_Graeve1
Any news on this?
Aleem
  • February 25, 2025
  • 2542 replies
  • February 27, 2025
HI ​@Aleem ​@Frank_De_Graeve1 ,
Sorry for the delayed response! Do you know if the missing variables are specific to a certain type (like text, color, or numbers), or are all variables missing entirely?
Could you please check that the library files are in a project rather than still in Drafts?
I'm trying to replicate the issue, so any additional details you provide would be greatly appreciated!
Toku
Aleem
  • February 27, 2025
OK. I’ll do as guided now and update you in a jiffy.
Aleem
  • February 27, 2025
The library file is confirmed to be inside a Team project folder and not in a Drafts.
Next Generation
having same issue Some applied library variable disappeared suddenly while working my new file but in same project where main file is. I have checked in main file library has all the variables in it. its properly published. As I was able to access all variables in new file before and they just disappeared some hours ago i am sure there is some kind of new bug introduced
Next Generation
Problem solved variables were hidden form publishing form settings
