Variable Fonts italic axis
  • February 1, 2024
  • 7 replies
  • 3473 views
Celine8
Hi everyone,
I have noticed that Figma does not display a slider for the italic axis. This only happens if the font is created with a slant axis. Is there a reason why it is not possible to select a position within the italic axis on a slider interface? According to the specs, the italic axis allows a scale interpretation.
Let me know, Céline
  • 2417 replies
  • February 2, 2024
Hi Céline,
Thank you for getting in touch. I want to make sure I’ve fully understood your question—are you asking about how to italicize text? As you noted, this can be achieved by applying a slant. If you’re working with static fonts, you’ll need to select the specific font styles that are italicized.
You might find this page helpful for a deeper understanding: Variable fonts support in Figma.
If there’s something crucial I’ve overlooked, could you please direct me to the specific documentation that mentions the italic axis allows a scale interpretation? I’d be more than happy to look into it!
Toku
Celine8
  • February 2, 2024
Hi Toku,
Thank you for your fast reply. Exactly, I was working with a variable font and intended to achieve an “animation” between upright to italic. However, the font I was using was mastered with an italic axis. (Because of the styl-linking in Microsoft, which is not working if you have a slant axis btw.) As I said, accordingly to the specs it’s not forbidden to create a semi-italic, see here: ital design-variation axis tag (OpenType 1.9) - Typography | Microsoft Learn it only specify that the value should sit somewhere between 0 and 1. So I wondered weather Figma is planing to change that in the near future?
Merci,
Céline
abhishekjunghare
Yes, the italic axis slider is missing. Currently, we can either use an upright (ital=0) or italic (ital=1) version of the font, but not semi-italic (ital=0.5) or other italic angles in between (ital=0.2 or ital=0.6). This should be fixed as it’s limiting the potential of variable technology. If you are giving variable axes to choose from, then it should include all the axes a font supports.
Figma_hW4Pqe4lSo
Celine8
  • February 8, 2024
Oh this is great news. Can you give already a date by which you will have fixed it?
  • 2417 replies
  • February 8, 2024
Hi all,
Thanks for the feedback. As I shared with the internal team, we took the approach of interpreting it as a on/off value, so the current spec for variable font italics is on or off. We keep hearing you and consider for the future improvements.
Toku
Roman_Shamin
Folks at Figma, please reconsider this issue.
Since ital is a full-fledged variable axis, it should at least be listed in the Variable tab, even if the axis only would allow values of 0 and 1.
However, as rightly noted above, not allowing intermediate values for this axis limits the entire purpose of variable technology.
Celine8
  • March 31, 2025
Hi Figma-Team,
I’m checking in here again on this topic. Wondering if you are about to change this any time soonish?
As described above, that the italic axis at the moment is even more hidden then it used to, if I remember correctly. Means the font looks broken, because if you have a variable font with 2 axis (wght, ital) you are only able to access the italic instances after changing the default cut.
Happy to hear your thoughts on that. And thank you for further checking.
