Text is showing as filled outline stroke
Naoman
Hey Community,
I am facing an issue in Figma text. My text sometimes shows as filled outline stroke but its editable which means its still a text. When I export it it also show it there as well.
  • 2526 replies
  • March 26, 2024
Hi there,
Thanks for reaching out. According to the help center article;
Figma Learn - Help Center
When you use outline stroke, Figma will:
  • Convert text layers from editable text to vector paths
  • Not combine any objects or layers you selected into a single layer
When Outline stroke is applied, each glyph (or letter) converts to its own vector node—so still you can edit each glyph individually.
Could you please explain a little bit more about your expected behavior?
Toku
Naoman
  • April 3, 2024
Thanks for this solution. But the problem is different. I don’t know what happened to my Figma. It all started when I was working on the mobile app design and used the material m3 design library and published that library. After that, I am getting this issue on almost every Figma file of mine. Its editable means I can change the text which means that it’s not outline stroke. when I zoom out it’s good but when I zoom in it’s showing filled. It also shows me the same when I export it as png or JPG. This is frustrating as it does not help in creating the projects from scratch on the new Figma file.
Naoman
  • April 3, 2024
zoomed in
Naoman
  • April 3, 2024
zoomed out
  • 2526 replies
  • April 4, 2024
Thanks for sharing the screenshots. Yeah it looks strange. I tried to replicate it but I couldn’t. WSo, would you be able to share the file link with access to support-share@figma.com? It won’t affect your billing. I hope I can investigate it further. If you prefer a direct support from our support team, you can reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new
Thanks for your patience.
Toku
