Chasen
Mar 5, 2024 1:05 AM UTC
Text in resume pdf doesn't copy and paste correctly
When I export my resume as a pdf, everything looks correct. However, when I try to copy and paste the text, many words are misspelled or have random characters in it. This is a big problem for when companies auto read my resume.
Mar 5, 2024 3:27 PM UTC
Hey Chasen! Thanks for flagging this. Can you clarify if the issue (copy and paste the text) happens after you export the PDF from Figma? If so, we can investigate on our end.
(If this PDF was not exported from Figma, the issue would be from the PDF source instead of Figma.)
Chasen
ChasenAuthor
Mar 5, 2024 9:12 PM UTC
Hi, yes the issue only occurs after exporting the pdf from Figma. Copy and pasting the text from inside Figma has no issues.
I mostly fixed it by moving the properties to a new frame and retyping some of the text, but a couple letters are still not correct.
Mar 8, 2024 10:27 AM UTC
Thank you for confirming! I’ve escalated internally to the engineering team to investigate the issue - while I cannot set an ETA yet for the fix at this time.
johntk22
Mar 8, 2024 1:28 PM UTC
Ensure that the font used in their username are properly included in the PDF file. When font are not attached then PDF viewer can change the font result in character are missing and misspelling.
Mar 8, 2024 3:18 PM UTC
Hi everyone! Thank you for sharing a workaround @johntk22!
To be transparent, we’re not actively investing in our PDF Export quality now, but it would be helpful to have a copy of your file so our engineering team can investigate further to implement a fix in the near future. It’s in our radar!
If you can’t share your file here, feel free to share a copy of your file by reaching out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Please use your Figma account email, include the link of this thread, a link to the file, and share it with support-share@figma.com as an “Editor”, so they can take a closer look. Thank you.
zora
Apr 27, 2024 8:19 AM UTC
I’ve experienced the same issue and managed to resolve it with this amazing plugin: https://www.figma.com/community/plugin/1255146474787882010/pdf-export-with-text-and-vector-objects
PDF also ends up being smaller which is neat.
James_John
Sep 2, 2024 12:13 AM UTC
Thanks for sharing! I’ve tried this plugin too and it works great
Marios
Oct 28, 2024 2:09 PM UTC
same problem. The plug-in suggested above allows for 5 free exports.
