Suggestions for variable naming continuity between design and front-end?
Moshe_Bari
Hi Figma Friends!
I was wondering if anyone has had any ideas or workarounds when dealing with the dev-side of things for color variables. Currently we have a primitive color collection that is cross referenced with our semantic colors collection. Inside of the variable collection interface, we use groups to keep things organized and easy to use for our designers, but it seems like on the dev-mode side, Figma is translating the group names to individual variables.
So for example, we have a variable called “bg-neutral-primary,” which is inside of the “Backgrounds/Primary” group in our semantic collection. In Figma, this is great because the group name appears as a heading above all the variables in that group and since the variables themselves have a predictable naming structure, we can quickly search through them in the color panel. However, in dev-mode the variable name becomes “–Background-Neutral-bg-neutral-primary” which is too long and less than ideal. It also prevents our devs from using plugins like variables2css as they have to rename them one by one each time. The easy fix is to just call the variable inside of the group “primary” (instead of “bg-neutral-primary”), but then in Figma we have a bunch of variables that just show up as “primary” which makes them much more difficult to find and parse when working on and looking over a design. Curious if anyone has any suggestions for how they approach naming variable within collection groups that makes sense in both the design and dev context, or any plugins that do a better job of exporting variables in the way that they are structured in Figma? Thank you!!
leo31
  • 5 replies
  • July 1, 2024
You can try using the style export feature of the https://www.figma.com/community/plugin/1358096843519910876 plugin to see if it can meet your requirements.
Moshe_Bari
Hey Leo! Thank you for sharing, your plugin is the first I’ve tried that exported the semantic variables without adding grouping names to each individual variable! However, I could only find a way to export one collection at a time so each semantic variable just shows it’s root color as “NANANA” instead of the value from the primitive variables collection. Thanks again!
leo31
  • 5 replies
  • July 2, 2024
Hi, Bari.
Thank you for testing my plugin and providing feedback on the issues. I have now fixed this error. And I’ve decided to go back and refine this feature within the next two weeks, so that it can export based on the user’s presets.
Moshe_Bari
That fixed it, now seeing it cross-reference variables from primitives and it correctly translates variable names! Thank you!!
Alexandre_Navarro_Caldeira
Hey, I know this post is a bit old and I’m not sure if this is still relevant for you, but we solve this using the “Code syntax” property of the variables. Each variable has its specific name in code and you can set it differently for CSS, Swift etc. Not sure how it integrates with variables2css, but at least for viewing the correct variable name in Dev mode it certainly works.
