Remove Myself From a Team I'm a Guest In
  • December 16, 2024
  • 8 replies
  • 517 views
Samuel_Bacay
I was added as a guest to view a file for a hiring exam. It’s done now and the team still appears on my list of teams. How do I remove myself as a guest. I can’t find any resources on this.
Nellya
  • 603 replies
  • December 16, 2024
For file: Share button in file → Your name → Can view → Leave
Nellya
  • 603 replies
  • December 16, 2024
To leave a team click dropdown menu next to the team name → Leave team.
But check if you have any personal drafts in this team and move them to your own team. Because after you leave the team, you will lose all your drafts located there.
Samuel_Bacay
I’ve already read a resource about that. I can’t find the dropdown, or am I wrong to assume that ClickUp is a team?
Samuel_Bacay
I finally found out the right resource. It’s an organization and not a team. I wasn’t able to read the teeny tiny fineprint.
Samuel_Bacay
The customer support from ClickUp doesn’t seem to understand my problem. Is there a way Figma can remove me from the organization?
Nellya
  • 603 replies
  • December 16, 2024
Samuel_Bacay
Thanks! That really helped.
Marioly Vargas
I think I've found the solution. I was added to a team I didn’t create.
Here are the steps:
  1. Click on this section and select the team you want to leave.
  1. Navigate to 'Projects' within the team and select the project (I only have one project as you can see in the image).
  2. Once you're in the project, click on the 'Share' option.
  3. Click the arrow next to your name in the dropdown menu and select 'Leave'.
  4. Refresh the page and that’s it.
Note: I assume that if there are multiple projects, you’ll need to leave each one in order to fully exit the team.
That's how I was able to leave the team in Figma. Hope this helps! 🌈
