Project transfer - External 'owner' remains
Chris45
I have received a transfer of a project from an external vendor, but am finding that the Owner is still set to the external contact (they are a viewer-only seat in our instance). The only way around this I can find is to give them a full-seat temporarily so they can then go into the files so they can change the Owner (since only owners can change this setting).
This should be more streamlined - I would have thought that a transfer to my instance would simply make me Owner. (I’m the owner of the team/project and an enterprise admin). Or am I missing something?
  • 4864 replies
  • May 2, 2024
Hey @Chris45, sorry for the trouble and confusion!
Just to make sure I’m understanding correctly, was this a team or project that was recently transferred to you?
In Figma, the term owner is given to the person who created the team or project. But as a team admin, you have the same permission level as an owner. So, provided you are the admin on the team or project, there is no need to become the owner, because as an admin you should be able to remove them or they can leave the team after transferring ownership.
Chris45
  • May 3, 2024
Hi @dvaliao
I created a team on our side that they transferred a project into. The intent was that I would ultimately turn ownership over to another full-seat user in our instance but was unable to do so readily as the external contact was still set as owner (and viewer-restricted in our instance) in our instance. I wasn’t able to alter the ‘owner’ even though I am an admin and owner of the team. So gave them full-seat temporarily to alter this. Are you saying that if I removed them, then I would be able to change the owner? Or is there some other piece of the process I’m mucking up? Luckily this was only 15 Figma files but if it were numerous this would be tedious to have them go change each manually. (Bulk owner change?)
May be missing something but I think it would make sense when transferring, that whomever is receiving the files would be the new owner automatically.
  • 4864 replies
  • May 3, 2024
Thanks for the additional info!
Did you and the user outside of your Org use this process?
Figma Learn - Help Center
Using this process, the original owner is usually kept the same, but the resources within the transferred team would be moved, unless the original owner also transferred their ownership to you. It seems like that may not be the case, because if they also transferred ownership or left the project and removed their ownership, you should be able to claim the team as the new owner.
Chris45
  • May 17, 2024
Ok was able to figure this out…
Here’s the scenario: Accepted the transfer, and the external party came in showing as Owner on the project and files. As Admin, I was able to remove them at the project level and was then able to join the project as Owner. Simple, but maybe not so obvious 😀
@dvaliao Thanks for your help.
  • 4864 replies
  • May 17, 2024
You’re welcome, @Chris45!
Glad to hear you were able to figure it out. 🙂
