Aaron_Bailey1
Nov 27, 2024 1:38 AM UTC
Icons in design library not visible in UI after UI
My team has noticed that Icons in our design library no longer update their color (in the Figma UI component picker) when the Figma UI is in dark-mode. Prior to the new UI update, the icons would show up as white here so they were easy to see. Now our black icons show up on a dark grey background, making them hard to find.
I’m hoping to not have to update our design system to make all the icons white so I can find them, and then manually change them back to black when ever I place them on the art board. Not sure if it helps/hurts, but we have light and dark colors assigned to these icons in our library.
Kevin_Miranda
Dec 4, 2024 6:38 AM UTC
I have the same issue:
Is there any fix for this?
Aaron_Bailey1
Dec 4, 2024 10:11 PM UTC
Found a solution.
In your design library, make sure the component container has a white background, but the individual component variants have a transparent background. This should give your icons a white background in the UI picker, but not include the white background when you place the icons in your file.
I think you can also throw all your icons in a frame with a white background for the same effect, but I just did it component by component.
