Nico008
Oct 2, 2023 12:30 PM UTC
"Go to main component" doesn't focus correctly
Hello,
Since a few days, when going to main component in library, it shows me the good page, but focus is not set on the selected component. Is it a bug? something mine?
Thanks in advance!
Mathieu11
Mathieu11Solution
Aug 26, 2024 8:05 PM UTC
@Gayani_S Found another example, and your instructions solved the issue, thank you very much!
This was happening in the app. Using a browser I’m not normally using for Figma, the behaviour was different, as the Restore Component prompt appeared. Clearing the cache and restarting the app solved the issue, i.e., the Restore Component prompt appeared there too.
Yulin_H
Oct 6, 2023 4:36 AM UTC
This issue is also happened to my desktop application.
Yulin_H
Oct 6, 2023 4:39 AM UTC
FYI, it can focus on the right main component, but lost the location auto track.
Nico008
Nico008Author
Oct 6, 2023 10:02 AM UTC
Hello Ryan,
In my case, it’s also in desktop app, and as Jennifer_Lyle and Yulin_H said, focus is working, but zoom on component is not. (sorry i wasn’t precise in my original message)
Video 1: In this case, instance and main component are in different files (library is linked in the instance file) and it fails.
Video 2: the instance is in the library itself and it works
Hope it can help. Thanks!
Timmy1
Oct 6, 2023 5:48 PM UTC
yep… also getting this. its REALLY annoying!! it takes me to the page but doesn’t take me to the actual component so I have to zoom in and find it. 😦
ysjcapelle
Oct 9, 2023 9:50 AM UTC
Same here! Post says it’s solved, but it’s not solved at all. I already submitted the form just a few moments ago, including the screen recording.
Ben_Smeets
Oct 9, 2023 12:46 PM UTC
It’s a bug, happened after the update of a couple of weeks back. Figured it would be obvious and figure itself out, but it seems to still be there.
Oct 9, 2023 4:45 PM UTC
Hey there, thank you for contacting support directly, and sorry for the confusion!
The marked solution is specifically for the first user. Support is still waiting for their reply with the requested info. To be transparent, support isn’t able to flag this as a specific bug until they can consistently reproduce the issue, so they can work on the fix.
Oct 10, 2023 12:50 PM UTC
I have the same issue, hope this gets fixed sooner than later! 👌t2:
OnlyRodas
Oct 10, 2023 10:58 PM UTC
Same boat, buddy! Hoping they’ll squash that bug real quick. I’m stuck trying to hop over to the main component in another file and can’t swap it out for one in the current file. Fingers crossed for a fix soon!
Carey_Smith
Oct 11, 2023 7:04 PM UTC
Also seeing this issue on Desktop (mac). If ‘Go to main component’ still selects the right layer for you, pressing 2 will focus to the current selection (which is the workaround I’m using for now)
