Getting the original image file name from the API
  • November 9, 2021
  • 3599 views
Asad_Khan
Figma doesn’t keep the original file names for image fills in the UI. However, there used to be a workaround for by getting the file name in Inspect > CSS code in background property.
As recently, Figma stopped showing original image filenames even in the generated CSS code, I was looking into API to see if the original image names are preserved anywhere. I couldn’t find the original filename on any of the endpoint JSON.
Perhaps I’m missing something or is this info isn’t anywhere in the API?
Scout_Digital
Super helpful. Thank you.
Josh.C
  • June 19, 2024
Looks like you can still grab the original file in Dev mode - no idea how this translates into the API though:
