Exported image does not appear the same as it does in Figma
Jake
I am unable to find a solution to exporting the image so that it appears the same way as it does in Figma. If anyone knows why this is happening and how to solve the problem I would really appreciate the help.
Screenshot:
Exported Image Does Not Appear The Same As In Figma
It may be worth noting…
  • The original image (a png) had a small border around the black center part creating a kind of frame with a color I did not want (it was part of the image).
  • I created a frame named “Crop” and used the “Clip Content” feature to remove it.
  • The frame named “Dollar Sign” provides a different background color (949494) thus creating a kind of border or frame around the black center part that has the color I do want.
  • The Image is nested inside the Crop frame and the Crop frame is nested inside the Dollar Sign frame.
  • There is a property called “luminosity” being applied.
  • Because of its purpose this was never meant to be very involved and the approach taken to achieving the outcome is pretty unimportant - it only matters as much as exporting the image properly matters).
  • While there may well be a much better way to achieve what I’m trying to do I am primarily concerned with a solution to exporting the image so it appears the same as it does in Figma.
Best answer by Paul_Soultis
Hi @Jake, I won’t speak to your process of clipping and cropping, but I may be able to help regarding your exporting.
I was able to replicate your issue and found that if you only apply luminosity to the frame, it will not export with that layer mode applied.
However, if you apply luminosity to the image layer/element, your exported frame should export that applied layer mode.
Jake
  • 48 replies
  • March 11, 2024
@Paul_Soultis
Hey that works! Thanks for showing me that.
Jake
  • 48 replies
  • March 11, 2024
Apparently there is another solution to the problem where the original configuration can be kept. The solution described in this response works where a blend mode (luminosity) was applied to the top level frame. I tried it and it works too.
Hi @Jake , that’s great and no problem, glad that solution worked for you and thanks for sharing an alternative solution as well.
fentanyl
  • February 21, 2025
I tried and I think there is  anthor method : uncheck ignore overlapping layers😀@Jake
